warning: seafoam for brake line - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2010, 07:29 PM   #1 (permalink)
View smilecow's Photo Gallery
Two days ago I bled my 99 camry's brakes and the brakes's reponse became really great.
Yesterday I went to my friend's house and saw his car burning carbon after seafoam. I was so impressed, bought seafoam and poured 1/3 thru brake line. 10min later I started to drive and it exhaled alot of carbon in the air. I took a step on brake but the response of the brake was not faster than yesterday.
I made a decision to bleed brakes for safety issue
Today I bled my brakes and I saw there was air in the brake fluid again.
After bleeding, now the reponse of the brake became goood again
My suggestion is that If you poured seafoam thru brake line, you should bleed brakes for safety.
smilecow is offline   Reply With Quote
Old 01-29-2010, 07:42 PM   #2 (permalink)
92alltrac's Avatar
View 92alltrac's Photo Gallery
sucking seafoam thru the brake booster hose should have nothing to do with getting air into your lines.
92alltrac is offline   Reply With Quote
The Following User Says Thank You to 92alltrac For This Useful Post:
curry.style (04-19-2012)
Old 01-29-2010, 08:07 PM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
brake line is not the same as brake booster....there's some fundamental differences.
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 01-30-2010, 07:18 AM   #4 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
exactly, you either didnt bleed them fully or are getting air into the lines.
zppeacock is offline   Reply With Quote
Old 01-30-2010, 07:36 AM   #5 (permalink)
mk2-1jz's Avatar
View mk2-1jz's Photo Gallery
vacuum line vs closed off master cylinder line/brake circuit. You could put seafoam in any rubber hose that sucks on the engine, but the most efficient is the brake booster vacuum hose.
NOT RELATED, you have another type of problem in your brake system that is siphoning air, or you did not perform the procedure correctly the first time.
What was the bleeding procedure you used? Please explain in detail, if done improperly you could be looking at serious danger.
Build Thread: http://forums.celicasupra.com/showthread.php?t=53215
~ Jamie - 1985 Supra - 1988 Camry
~ Supra, Its a Religion
mk2-1jz is offline   Reply With Quote
Old 01-30-2010, 11:02 AM   #6 (permalink)
View AlmightyCamry777's Photo Gallery
He's right, they're totally unrelated...its like saying changing your oil made your transmission fluid go down...
probably the need to bleed again, was caused by just some residual air bubbles hiding in the brake fluid lines or the master that got knocked loose, after a few stops.
AlmightyCamry777 is offline   Reply With Quote
Old 01-30-2010, 01:18 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If you have air in the system after days, then you may want to check for leaks. Or maybe it wasn't fully bled in the first place. For example, if you have ABS and there was air in the secondary pressure relieving circuit.
Old 01-30-2010, 04:47 PM   #8 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Feeding seafoam through the brake booster hose does not affect the braking system in any way. It goes into the engine.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-30-2010, 06:07 PM   #9 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
2 cents -
If someone is helping you bleed the brakes by pushing and holding the pedal down I usually tap the caliper/wheel cylinder I'm bleeding to dislodge air and facilitate its departure through that scrawny orifice. Using a 15” length of clear silicone tubing helps you to see the bubbles and direct the fluid to a more pleasant place.
Also – if doing this process to a high mileage master cylinder, you risk a latent failure of master cylinder itself for the following reasons:
If the brakes were working correctly before being bled then it’s likely the pedal was high and the brake pedal has not been pushed completely to the floor (m/c pushed to the ends of its travel) in a very long time!
Now that you’ve pushed this old m/c to the very end, its basically gone into no-mans land scraping up sediment and/or possibly cutting the rubber cups (pistons) on that sediment.
So be advised that the pedal may drop in the next couple weeks when the m/c fails!
This could explain what you’re experiencing now or perhaps you left a bleeder cracked open? This could allow air back into the front/rear line set.
Be careful and check everything over real thorough!
Did you install new pad or was this just a PM? Sometimes people overheat new brake pads after a fresh install and they get grabby. When the cool the next day they are less affective until they get warm again. This is somewaht dependent on the type and quality of part used!
Hope this helps!
73sport is offline   Reply With Quote
Old 01-30-2010, 06:20 PM   #10 (permalink)
Some pretty good advice.
People need to be aware of the feel of the master cylinder operation. If in doubt, inspect and replace. I've seen some go around 100K miles, others nearly 300K miles.
Old 04-18-2012, 01:24 PM   #11 (permalink)
View Zain's Photo Gallery
i have asked this question before in a different thread but did not get any reply.
can anyone tell me when should we seafome the engine
my engine online has 69k miles on it
should i still seafoam it?
thanks
Zain is offline   Reply With Quote
Old 04-18-2012, 01:41 PM   #12 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
With that few miles on it, I'd say no, don't bother. Unless it was driven by grandma and never saw more than 2000 RPM its whole life. Then I might.
BMR is online now   Reply With Quote
