Spacer size to fit is300 rims??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2010, 09:44 PM   #1 (permalink)
View .Camryman97.'s Photo Gallery
4th Generation Spacer size to fit is300 rims???
hey guys i just got some is300 wheels for my camry and i tried to test fit them at least in the front and i found out that the wheel rubs hard against the brake caliper
anyone know what sizer spacer ill probably need to pass the caliper???
thanks
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 01-29-2010, 09:59 PM   #2 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
depends if these are replicas or oem.. if they're touching the brakes, im guessing they're +50. Our cars can rock +40 easily, so try to grab a 10mm spacer. Good luck and post pics for us soon!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 01-29-2010, 10:14 PM   #3 (permalink)
these are oem i believe they came off an is300 and they still have emblems on them
do you know where i can find a 5 or 10mm spacer??
Old 01-29-2010, 10:24 PM   #4 (permalink)
[g4.Rep]
if i were you, i'd do research on what the flushest offset with those wheels since yr going the spacer route. But in regards to yr question, Ichiba makes them the cheapest that are hubcentric w/ extended studs.
Old 01-29-2010, 10:49 PM   #5 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Useless post;
That was the first set of wheels I found for the 95, but they also hit the rear struts. Not cool.
I know people do it, but I would avoid spacers. Its just not worth the risk of loosing a wheel.
Believe me, I walked away from a screaming deal on some perfect rims with new tires. It sucked!
73sport is offline   Reply With Quote
Old 01-29-2010, 11:00 PM   #6 (permalink)
could the rubbing also be caused by my open ended lugs or does that not matter
Old 01-29-2010, 11:34 PM   #7 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
hmm weird, i have the wheels and they fit fine...but very very close fit
however, i do have the supra TT big brake swap..maybe that's why they fit fine.
i'd recommend some hubcentric spacers. Toyota/Lexus hubs are the smallest JDM sizes...so yea make sure it's hubcentric...if u get regular spacers, u'll get vibrations
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 01-29-2010, 11:39 PM   #8 (permalink)
[g4.Rep]
Originally Posted by 73sport View Post
Useless post;
.. you shoulda done it! .. spacers are not dangerous at all if they're built hubcentric -so it does NOT SHAKE and STAYS CENTERED; and comes with longer wheel studs so that it'll compensate for the threads lost when the spacer is put on.
Majority of accidents are people running with spacers that are NON hubcentric with the original wheel studs. Like this one below, its cheap as hell but dangerous as well! .. stay tha fk away from these things. Running spacers is an expensive affair, but its what keeps yr car on the road- so don't cheap out.
This is the one i have on my car, its a 20mm spacer with 50mm extended wheel studs.
Pair of 20mm Wheel spacers w/50mm ext studs: $140
Install: $60
Its been working for me very well! .. over 2 years and not a single problem!
Old 01-29-2010, 11:51 PM   #9 (permalink)
View LUVLEXUS101's Photo Gallery
Install: $60
Did you cut off the tops of the old studs?
LUVLEXUS101 is offline   Reply With Quote
Old 01-30-2010, 12:55 AM   #10 (permalink)
[g4.Rep]
^ no.. the old ones were pounded out and the newer (extended) ones had to be pressed into the wheel hub itself in place of the old ones.
Old 01-30-2010, 03:33 AM   #11 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
just change to the v6 calipers and disk safer that way.
^ and leaving it that way!
Old 01-30-2010, 12:09 PM   #12 (permalink)
V8'sRGone
73sport's Avatar
Thank You! This is what people need to see! The JUNK here and the REAL thing with real studs that ALSO support the wheel!
I wasn't in a place to punch the studs and afford the extra expense of doing it with quality parts as you did.
Those look solid!
Good info to share!
Heck right now the TSW Volcan's i've got on there now have hub centers but no spacers. WAY TOO many people throw wheels on a rely on the studs and crap plates like that to hold the wheel. I should have went into more detail!
Like: Do it RIGHT or DON'T do it at all. Your machined hub and replacement studs are the right way!
Old 01-30-2010, 12:36 PM   #13 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
If you're touching the caliper, it sounds like the diameter of the rim is too small to fit the brake components in...
If the offset is like +50 like someone was saying, the rim would actually be closer to the strut, not the caliper.
I'd have to see pictures
RichieRichJP is offline   Reply With Quote
Old 01-31-2010, 01:29 AM   #14 (permalink)
well i need spacers all around to fit... im going to be giving the rims back since i didnt make any payments and because i cant afford the nice spacers that i will need
was really looking forward to it but if anything i might get new wheels this summer once my summer job is up and running again
Old 01-31-2010, 02:14 AM   #15 (permalink)
[g4.Rep]
^^^ ouch.. that's hurting. - move up to cali! .. i have wheels im kickin' around in my backyard that you can borrow- mostly 17" so you can re-use yr tires on them!
