Electrical Oddity - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2010, 03:01 PM   #1 (permalink)
Mark
View mwilde's Photo Gallery
Electrical Oddity
I have a 2000 Camry CE 4 cyl, manual. Its a daily driver US spec car. Recently, I noticed that sometimes my presets on the head unit zero out when I start the car. Nothing else is abnormal in terms of electrical accessories. I do most of my own work so I am wondering what the fix is.
I also have an Italian car so I am very familiar with electrical gremlins and this has all the markings of one given that it is intermittent and follows no reasonable pattern that I can detect. My wild guess is that there is a short in the ignition switch. Does it sound like I am barking up the right tree?
Mark W
Houston, TX USA
mwilde is offline   Reply With Quote
Old 01-31-2010, 05:00 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
you may want to check that the head unit(if its aftermarket) was installed correctly and is using the proper power and ground points. some guys just splice in where ever.
rusty9 is offline   Reply With Quote
Old 01-31-2010, 06:54 PM   #3 (permalink)
Mark
electrical oddity
Thanks. Its the original unit and I am the first owner. Nothing has been touched. I have thought about putting a new head unit with all the all the modern tech stuff in it but I want to be fairly certain that the problem is not in the head unit.
Old 01-31-2010, 09:17 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
It could be the battery is getting weak. How old is it? While the starter is cranking the motor, a weak battery's voltage can drop enough that the radio will lose its presets.
BMR is online now   Reply With Quote
Old 02-01-2010, 12:51 AM   #5 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
I'm gonna say weak battery.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 02-01-2010, 12:03 PM   #6 (permalink)
Gameroom cash: $303255
^ Or weak alternator. Have them both checked out. There are auto parts stores that will check the charging system out for free, while still on the car. Call around to auto parts stores in your area to find one that does and go there.
Mike
Old 02-01-2010, 02:21 PM   #7 (permalink)
Mark
electrical oddity
Funny y'all should mention this. It was cold last night and when I cranked the car up this morning, I cranked very slowly. I will test the battery tonite.
Old 02-01-2010, 03:52 PM   #8 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
I've had the same thing happen. It did that for a few days and then the battery finally crapped out and wouldn't start the car. I recommend replacing the battery ASAP. They can do some freaky stuff when they reach that point. Get an Interstate battery. They are built very well and usually keep working solid a year or two after the expiration date.
#2! is offline   Reply With Quote
Old 02-01-2010, 05:30 PM   #9 (permalink)
Mark
I bought one this morning after observing the slow crank. I will put it in tonight and provide a results recap.
Thanks to all who responded
Mark Wilde, Houston TX
Old 02-03-2010, 01:22 PM   #10 (permalink)
Mark
USA
Put a new battery in the vehicle. All is functioning well.
Thanks for the input from everyone.
