Still Have P0420 - 2000 Soloa SE - Replaced A/F, Rear O2 & Cat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2010, 03:55 PM   #1 (permalink)
Self-taught Mechanic
View boofertjustice's Photo Gallery
4th Generation Still Have P0420 - 2000 Soloa SE - Replaced A/F, Rear O2 & Cat
My girlfriends 2000 Solora SE (CA) has had the P0420 problem for some time now. Here's what I've done so far...
1) Scanned, got P0420
2) Replaced front A/F sensor
3) Reset CEL, drove, CEL came back, scanned, got P0420
4) Replaced rear O2 sensor
5) Reset CEL, drove, CEL came back, scanned, got P0420
6) Replaced cat
7) Reset CEL, drove, CEL came back, scanned, got P0420
I'm kinda at a loss of what to do next.
boofertjustice is offline   Reply With Quote
The Following User Says Thank You to boofertjustice For This Useful Post:
pgmomni (01-31-2010)
Old 01-31-2010, 04:42 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Originally Posted by JJJJJJ View Post
None of what you did is 04020 related, you put a lot of money into it already - it's carbon buildup or VSV modulator.
In this order:
clean/replace Vaccum lines
check EGR modulator and EGR valve for vaccum
clean EGR valve
replace EGR VSV modulator
OK, are we talking about a P0402 (which points to an EGR flow issue, as J^6 points out), or P0420 (cat efficiency below threshold), which seems to be what boofer is trying to troubleshoot?
Old 01-31-2010, 04:50 PM   #3 (permalink)
hill8570's Avatar
Ass-u-ming that we're talking a P0420, have you checked the exhaust system between the exhaust manifold and the rear 02 sensor for any holes or leaks?
Old 01-31-2010, 04:51 PM   #4 (permalink)
Hill is correct, the P0420 (cat efficiency below threshold). As I wrote and double checked twice before posting. Please read carefully.
Read it as an EGR issue - maybe it's a cat issue.
I said I replaced the cat. Please read carefully.
Did you use Bosch, NGK/Denso, or other for the 02 sensors ?
Bosch sensors, A/F & O2.
Do you have CA emission ?
CA with A/F sensor, as I mentioned. Please read carefully.
What model of cat did you install ?
A metal with some stuff inside to burn off excess gas. No brand name.
The sensors were tested via ODBII and seemed to be within their respective ranges.
No.
