Burning smell from heater - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2010, 10:30 PM   #1 (permalink)
View kokyaw's Photo Gallery
Hi all,
I am a newbie and have a 1998 Camry V6. I recently noticed a burning smell from the heater. It is like 'comes and goes'. When that smell comes, I let the air circulate in the car (I drag that circulate/not-circulate notch to the left). It stops the smell but I know I am not solving it for good.
May I know where the smell is coming from? Will it need major fix (how much will it be?)?
Thanks so much,
Rob
kokyaw is offline   Reply With Quote
Old 01-31-2010, 11:57 PM   #2 (permalink)
View 1993Camry_V6XLE's Photo Gallery
USA
Originally Posted by kokyaw View Post
Hi all,
Thanks so much,
Rob
I have 93 Camry and oil was leaking from the oil filter mount onto the exhaust pipe right underneath it. It doesn't smell when i drive but when I come to a stop or let my car idle it would smell really bad. All I did was change the O ring in the oil filter mount and cleaned the area. The oil leaked stoped and the smell went away. It cost me $8.00 for the part. I don't know if you have the same problem.
1993Camry_V6XLE is offline   Reply With Quote
Old 02-01-2010, 12:50 AM   #3 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
It's very possible that you are just drawing in smelly air from outside (from other car's exhaust/fumes). The Gen 3/4 Camry's don't have a cabin air filter, so whatever you draw in, you're breathing in that form.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 02-01-2010, 07:25 AM   #4 (permalink)
Thanks a lot for the responses.
Actually, I smell that only when I turn on the heater. I don't smell anything when I stop or let the engine idle.
Old 02-01-2010, 03:40 PM   #5 (permalink)
Gameroom cash: $115300
View TCam01's Photo Gallery
yea i have the same exact problem with mine it smells like sausages and my friends always complain i wonder what it is too. it only happens when the heats on and i don't have to be in idle an its deff comin from my car not outside air
Yota Camry 2001 5S-FE 105,430 Miles+
TCam01 is offline   Reply With Quote
Old 02-01-2010, 08:01 PM   #6 (permalink)
yeah, that exactly is my problem.
Old 02-01-2010, 09:57 PM   #7 (permalink)
Dave's
Gameroom cash: $121050
View Dave's's Photo Gallery
You may want to pull the heater blower resistor and see if there's any visible damage. They can produce a burning smell as they start to go bad. They can go bad for no apparent reason or possibly because the cabin air filter is too clogged on models which have the filter.
Dave's is offline   Reply With Quote
Old 02-02-2010, 12:08 AM   #8 (permalink)
May I ask where the resistor is? I saw on google said it is under the passenger's side dashboard, near the firewall (I don't know what firewall is). Is it hard to take out?
