Help! Stranded, engine overheAting! Gen 3 cam - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2010, 02:06 AM   #1 (permalink)
View illuzionx's Photo Gallery
3rd Generation Help! Stranded, engine overheAting! Gen 3 cam
Ok, firstly sorry if my typing is wierd, I am stranded and using my iPhone .
Well here's the deal, I went to pick my mother up frm the station and now we are stranded at the station.
As I was leaving I noticed he car was idling roughly, and as I arrived I noticed the engine temp almost hitting the red!
Luckily I hAd enough time to safely park, but I don't know what's wrong.
Firstly, how long should I wait till it's safe to check my radiator coolant?
Secondly, what else should I check?
Thanks 4 the help.
illuzionx is offline   Reply With Quote
Old 02-01-2010, 02:36 AM   #2 (permalink)
Needs more TRD...
2unknown's Avatar
View 2unknown's Photo Gallery
i would check the coolant over flow tank for coolant..empty or not?
give it some time to cool down as it was near red...opening hood would help cooling faster...
on average for me, its about a good +30 minute..to be on the safe side
do you have a cloth or rag to open the radiator cap, just for precaution...
hope this helps a bit..
[98 Camry LE][5SFE @ 260,XXX][Bucket Seats w/ TRD Belt Pads][Injen SRI][Brass Hood-spacers][Yellow Fogs][Grounding Wires][Digital Voltmeter][Black Grill w/ TRD Emblem][Partially De-badged][KYB Excels w/ TEIN S-Techs][Amber Sidemarkers][Clear Corners][NGK Copper]
2unknown is offline   Reply With Quote
Old 02-01-2010, 12:46 PM   #3 (permalink)
View Judge2's Photo Gallery
Also check the oil level
Check the coolant level, check the oil level.
Judge2 is offline   Reply With Quote
Old 02-01-2010, 01:35 PM   #4 (permalink)
View kento16us's Photo Gallery
Probably a stuck thermostat in the closed position if everythinig else looks ok. Not hard to change.
2000 Camry, 4 Cyl, Auto, Federal, 95k and climbing
kento16us is offline   Reply With Quote
Old 02-01-2010, 06:25 PM   #5 (permalink)
_
Gameroom cash: $221635
View uuuuu's Photo Gallery
Can you remember if the radiator fans were working?
uuuuu is offline   Reply With Quote
Old 02-01-2010, 10:40 PM   #6 (permalink)
View JBlacks's Photo Gallery
hate to say it but it could also be a blown head gasket.
JBlacks is offline   Reply With Quote
Old 02-03-2010, 11:38 AM   #7 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
just before you noticed the temp gauge going up, were you sitting idle in a parking spot, did you just get off a highway, were you in stop and go traffic?
i would check coolent level first.
if you just got off a highway, i would place blame on a faulty thermostat. if you were idling or stop and go traffic, i would check themostat, cooling fans and radiator. also, how old is the water pump? ive seen some with plastic fins and they actually broke off over time and not circulating coolent. but the water pump is not very likely.
ghettosled is online now   Reply With Quote
Old 02-03-2010, 12:44 PM   #8 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
V6 or I4?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 02-03-2010, 05:36 PM   #9 (permalink)
View sterfry2004's Photo Gallery
As said, coolant and oil are probably the biggies. Make sure you take the oil cap off, too, don't just check the dipstick because JBlacks is right and you might not see the milkshake on the dipstick. Make sure your fans are running, and the thermostat is opening. I think you can check the thermostat by feeling the radiator hoses for heat while it's running, but you might have to wait until the engine is cool before you can touch it.
Make sure you get it fixed, though, and don't push the temps just to get it home. I did that in a Jeep and blew the headgasket, cracked the head, and I'm in a full rebuild now.
sterfry2004 is offline   Reply With Quote
