Full Tune Up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2010, 12:37 PM   #1 (permalink)
View 1993Camry_V6XLE's Photo Gallery
3rd Generation Full Tune Up
Hi everyone,
I'm planning on doing a full tune up my 93 Camry V6 XLE but I don't know what to do. What does full tune up consist of? Can I do it myself or do I have to take her to a shop. If I do have to take her to a shop how much do you think its gonna cost me? Thanks
1993Camry_V6XLE is offline   Reply With Quote
Old 02-01-2010, 01:08 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
fuel filter
oil change
plugs
spark plug wire
cap/rotors
air filter
tb cleaning
depending on miles and service timing belt, water pump, belts
^ and leaving it that way!
Old 02-01-2010, 01:12 PM   #3 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
+PCV valve
Transmission flush with pan removing and cleaning
Differential flush (on 96 V6 it is separated from transmission)
Brakes bleeding
Power steering flush
Coolant flush
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 02-01-2010, 01:36 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Originally Posted by chronoti View Post
fuel filter
oil change
plugs
spark plug wire
cap/rotors
air filter
tb cleaning
Originally Posted by Nervous View Post
+PCV valve
Brakes bleeding
Coolant flush
Since you, personally, are concerned about your poor performance, I would prioritize as follows (and add oxygen sensors). The first six are pretty easy to DIY, relatively cheap for parts & materials ($150, at most, for top of the line parts), and have a lot of bang for the buck. Frankly, I'd do the first three, then take it from there. Oh, BTW, if you can borrow a compression gauge from Autozone or another parts store, checking compression would be a real good thing to do while you're messing with the spark plugs.
tb cleaning
plugs
spark plug wire
PCV valve
cap/rotor
air filter (check it, anyhow)
Oxygen sensors (depending on age)
fuel filter
oil change
Brakes bleeding
Coolant flush
Old 02-01-2010, 01:54 PM   #5 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Check timing. If it's been a while, do the t belt, water pump, seals and tensioners. Also, thermostats are cheap enough to where you might as well just change that.
Same goes for the air filter.
Chris Crash is offline   Reply With Quote
Old 02-01-2010, 02:32 PM   #6 (permalink)
3rd Generation
Thanks to everybody
Old 02-01-2010, 02:59 PM   #7 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Don't just check under the hood...
While you're at it, get the car up in the air and inspect your suspension, frame, exhaust, etc. Don't limit your tuneup to just the engine/transmission.
BlueFusion6851 is offline   Reply With Quote
Old 02-02-2010, 10:10 AM   #8 (permalink)
View zq_frank's Photo Gallery
use seafoam. there are a lot of video instrusctions on youtube.
The best tune up I ever had.
zq_frank is offline   Reply With Quote
Old 02-03-2010, 01:54 AM   #9 (permalink)
View Judge2's Photo Gallery
Not quite tune up, but check hoses and drive belt`
I'd start with checking, and likely changing, air filter, spark plugs, then plug wires, distributor and cap. Wipers blades.
I never get around to some of the things that others have suggested, but I'd add, visually check the condition of the radiator hoses, and drive belts. If they bad, they can strand you on the side of the road. Also, check the color, and maybe smell of the fluids, coolant, brake, transmission, and if they look old, burnt contaminated, change them.
Judge2 is offline   Reply With Quote
Old 02-03-2010, 10:11 AM   #10 (permalink)
How hard can it be?
+1
