Originally Posted by yoyo9598
....Someone also mentioned Ignition coil but ECT sounds like it is easier to check.
What do you think about the ignition coil suggestion? I saw in other posts that if it is the ignition coil that it typically means it will have issues starting (which I havent really experienced).
Thank you so much!!
I think if the coil were the problem the engine would act the same way hot or cold. unless the coil were cracked or worn out, then its possible heat could raise the resistance through it. But i think that's unlikely that would cause your stalling problem. You can check the coil with a v.o.m. for resistance, there are links here for the factory manual that tells you how. ( It is easy if you know where to put the probes and what number you want to see on the ohm scale.)
One thing that's probably certain, it's not a fuel problem, but a problem with some electronic part that supplies fuel or spark. This year car has OBD so im surprised your check engine light isnt on and throwing a code for you to read.
Things to check: EGR valve -i know you cleaned it, but they are problematic to clean since you can't take it apart. Since the engine runs better with the egr disconnected, that's a big clue. i'd find a junkyard unit that seemed good then soak it in solvent overnight before blowing it out with air, bolt it on then see if the engine performance changes. If it does then you know what to replace. and at worst you only spent $10 and now know you need a new egr valve.
MAF sensor
cold start valve, if fitted (if your engine has one, its possible its spitting fuel into the engine when it doesn't need it.)
A very bad vacuum leak (cracked, missing, or mis-routed hoses or bad brake booster.)
PCV has suction but engine didnt die when plugged with finger (one link said something about this).
The engine doesn't necessarily have to stall when you do that, but the idle should change. PCV valve is a simple contraption, and it is one possible, but unlikely, cause for stalling, they rarely go bad! Pull it out of its hole, shake it, if it clicks when you shake it, it is good. if it doesnt click, replace it (they can't really be cleaned.)
