98 Camry V6 Starting Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2010, 09:14 AM   #1 (permalink)
View camtoy's Photo Gallery
98 Camry XLE V6 (1MZFE) @ 80,000mi. on motor 115k on body.
The other morning I went to start the car it would crank but wouldn't turn. It was running fine the night before. Fuel pump was working fine and there was spark. Put a bit of starting fluid and the car went up to 1k RPM and than cut right back off. Again it would crank but wouldn't turn. - On a side note it was around 5F the night before. The car than started up fine and gave me no problems until the next cold morning but again started around the afternoon. The car hasn't given me a problem starting since the second time and much wasn't done.
What could have given me that start problem? Someone said crank sensor could be going bad, is it possible?
camtoy is offline   Reply With Quote
Old 02-04-2010, 09:22 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Battery original? How many minutes of driving do you do between starts? Either you are not charging the battery enough - Check with volt meter or the temperature at 5F there may not be enough power to crank the engine.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-04-2010, 07:44 PM   #3 (permalink)
A friend tried to jump the car. We left the jumps connected for atleast 30 min. and he revved it for 5 before we tried to start the car and it still would crank but not turn. I had gas and I only use premium. Also the battery isn't a even a year old yet. Its a duralast gold.
Old 02-04-2010, 08:17 PM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
98 should have the 3 coils and wires pull one f the wires running to the back and check for spark, if you have spark look at frozen gas lines/ dead pump
^ and leaving it that way!
Old 02-05-2010, 12:47 PM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
How's the timing belt?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-06-2010, 07:04 AM   #6 (permalink)
Timing belt is only 10K mi. old. Like I said it was only on those 2 cold days it didn't want to start. Not it starts up just fine.
Old 02-06-2010, 08:31 AM   #7 (permalink)
Gameroom cash: $155150
View wilsonman02's Photo Gallery
my car kinda does the same thing. Its a 2000 4cyl, but on really cold morning it starts "hard". It sorta stumbles to turn over then it revs up and its fine. I cleaned the TB, got new plugs, wires, and coil packs. Its better now, but if its 10 degrees in the morning it still does it a little bit. And i have a two year old toyota battery, and i just had it checked out and its still fine. Dont know what does it other than just cold weather.
wilsonman02 is offline   Reply With Quote
Old 02-06-2010, 12:35 PM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
So this happens only when low temp?
Maybe it's icing in the gas line. Also check the engine coolant temperature sensor, the two wire deal that tells the ECU the temperature:
http://www.rockauto.com/catalog/moreinfo.php?pk=482090
Crank sensor is just a magnetic pickup. They can go bad, but there are others in the front of the line.
Old 02-07-2010, 10:56 AM   #9 (permalink)
Thanks John I am going to check the coolant temp. sensor today although I haven't had any start up problems even with the snow storm.
