Auto to Manual Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2010, 09:07 PM   #1 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
View Bankos66's Photo Gallery
3rd Generation Auto to Manual Swap
First of all I am slowly seeing the potential for my car even tho most of my friends call it the ghetto car but I want to do a auto to manual swap. I am a complete noob at this so do you guys know where I can get one at a reasonable price and how to install and remove the old one. thanks
Bankos66 is offline   Reply With Quote
Old 02-05-2010, 09:15 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
to TN!
Search, search, search! One of our rules around here. Always research on here and google!
'07 Honda Ruckus Big Bore
Old 02-05-2010, 10:06 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
a good search of the topics here will yeild most of what you need to know. however without the right tools it can be very hard to do. its something youll need money, time and equiptment to complete it.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-05-2010, 10:21 PM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I just finished my swap, PM me if you need help!
But basically...you need the manual wiring harnesses (engine and dash, you miiiiight need cowl harnesses too), manual ECU, clutch start switch unless you bypass it, pedals, all the other interior parts, cables, transmission mount, the motor mounts are different as well, so you'll need those the auto has beefier mounts because it's heavier so if you try to reuse those mounts the engine will sit up too high for the hood to close.
Let's see what else. You'll need the flywheel, clutch, master cylinder, all the clutch lines (might want to consider SS clutch lines from speedsource.com or somwhere similar.) You'll need a manual EVAP canister. The automatic has a huge boxy one, that will get in the way of the bell crank. The manual has a small round one. Someone told me something about a bearing needed to be flipped or moved when you go from auto to manual on the same engine, but that didn't concern me as I swapped engines with trannys.
If your auto has a factory alarm, the computer for it needs to be removed to get the clutch pedal in. You can relocate it or just leave it off like I did. The easiest way to make the hole for the clutch pedal/master cylinder would probably be to remove the dash because then you have access. Maybe a dremel tool would help instead, they're small enough to get at the right angles from under the hood. I had a bitch of a time making the hole. There is a punch out in 1 of the 2 layers of the firewall. So unless you have enough room to punch, good luck.
You don't need this, but it would look better if you got the manual radiator that didn't have the A/T cooler and A/T cooler lines running to it.
I feel like I'm forgetting something...
Chris Crash is offline   Reply With Quote
Old 02-06-2010, 12:33 AM   #5 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
thanks for the feedback guys
