3VZ throttle surge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2010, 11:16 PM   #1 (permalink)
View asushi's Photo Gallery
3VZ throttle surge
93 camry V6 - 3VZ motor
engine is warm, I'll flip the TB open for a split second: revs up, drops down below idle, surges up above idle again. Sounds like a sticky IAC to me. Are these problematic in this car? Is there an easy fix?
asushi is offline   Reply With Quote
Old 02-06-2010, 11:43 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Pretty much all of these rigs (including the 3VZ) that vent the PCV valve into the TB have problems with the TB, throttle plate, and IAC getting gunked up after a while. Cleaning the TB, the throttle plate (especially the edge) and the IAC port is usually worth trying.
Old 02-07-2010, 10:12 AM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
yeah its an easy fix. remove it and clean it out with throttle body cleaner. if yours is really high mileage expect a lot of black gunk!
rusty9 is offline   Reply With Quote
Old 02-08-2010, 11:45 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
Here's a DIY thread with pix showing how to remove and clean the IAC valve on the 3VZ-FE.
Link to thread
I did this a while back and it fixed a surging idle. I'd advise skipping steps 7 thru 9, though. Mine was pristine clean inside with adequate lube. The way it's sealed, I don't see how it could need to be opened up & cleaned/re-lubed.
In the picture in step 10, pay special attention to cleaning the valve area in the center. Get in there with a Q-tip or something to get all the gunk out. That's where it really matters. Mine was caked up really bad there.
BMR is online now   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
asushi (02-09-2010)
