walbro 190, will it make a difference? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2010, 07:52 AM   #1 (permalink)
old red
old red's Avatar
View old red's Photo Gallery
hi guys
i got a '00 camry V6, with i/h/e, 5 speed
i wana add some more power
i'm thinking fuel pump
so how about this walbro 190 pump?
will directly fit? or does it need some sort of fabrication?
also, will it decrease my air/fuel ratio?
i'm looking for something around 13.5 AFR
Think deep, act simple.
old red is offline   Reply With Quote
Old 02-07-2010, 08:16 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
it more or less a direct fit, you just need to splice the connector,
a/f change no.
you want to change the a/f your gonna need a piggy back like the smt-8, you will need to trick the ecu to dump more fuel or else no matter what you do your gonna sit at 14.7
^ and leaving it that way!
Old 02-07-2010, 09:26 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
even tuned the stock motor needs no added fuel. it wont help you unless your boosted or go heavy into the NA mods. if your getting a good deal on it then it may be somthing good to pick up so that if you ever do go FI youll have a pump already(even thought its only works well on low boost).
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-07-2010, 07:45 PM   #4 (permalink)
old red
old red's Avatar
a/f change no.
that's what i thought too
anyways, how does the ecu know how much fuel goes from each injector?
is the oxygen sensors in the exhaust?
cause beyond the point of combustion, the only form of monitoring is the oxygen sensors and the EGR valve thing... i dont get it
i thought the injectors get instructed to inject fuel for a certin time according to the MAF readings...etc
and since the pump gives a constant pressure, with the fixed time that cant be controlled after combustion... seems to me that adding more pump power will give more fuel... check me!
Old 02-07-2010, 07:49 PM   #5 (permalink)
old red
old red's Avatar
that's my girl
Old 02-07-2010, 09:32 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
the ECU has a fuel map that tells the injectors how much fuel to let in based on RPM, air temp, throttle position and a few other factors (mostly from the MAF). the piggy back intercepts signals from the MAF and changes them on their way to the ECU.
the O2 sensor is on each bank of the exhaust and pased the cat(if you have one).
EGR does nothing but get in the way, and has nothing to do with the fuel curve unless it breaks and throws a CEL(which is triggered by a reading in the O2 sensors).
the issue in your reasoning is that you think you need more fuel. you dont. if you were boosted or had higher compression then you would.
R.I.P.
Car Domain:
Old 02-07-2010, 09:37 PM   #7 (permalink)
old red
old red's Avatar
dude a AFR of 13.5 gives optimum performance for NA sets
I've seen it on entirly stock v8s
i'm just looking for a cheep way to get an edge that's all
Old 02-07-2010, 09:55 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
good lord man, both of us are telling you to buy a tuner. the pump wil do NO good!
R.I.P.
Car Domain:
Old 02-07-2010, 09:59 PM   #9 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
whoa dude, what kinda mods do you have in there? Sounds sweet..
ty**20 is offline   Reply With Quote
Old 02-07-2010, 11:11 PM   #10 (permalink)
I HAS BOOST!!!
bigbird's Avatar
he has the mods listed in his first post...I/H/E (intake, headers, exhaust thought i thought he had more). and yes, that thing sounds great.
R.I.P.
Car Domain:
