I purchased a dead 94 M/T Camry (Federal) last week that has no spark when I hold the spark plug attached to any of the 4 spark plug wires next to ground. I have done the following tests:
1. Yes, distributor turns, so timing belt is not broken;
2. Checked resistance of primary coil: .60 ohm (range .38-.55)..OK
3. Checked resistance of secondary coil: 4.5K ohm (range 9-14K)...LOW!!!
4. Checked resistance of pickup coil G+ & G: 214 ohm (range 185-2750)...OK
5. Checked resistance of picked coil NE+ & NE: 430 ohm (range 370- 5500)...OK
6. Checked that I have 12V on coil +...OK
This Camry has the coil and crank position sensor built into the distributor. Any thoughts on what else I can check? Is it possible that the the coil being out of range would produce no spark at all? Thanks for any further ideas. Hate to just swamp parts.
Also, I have no check engine codes (I jumpered the connector by the strut tower and the check engine light just flashes quickly, indicating no codes).
Sounds like you've got an internal short on the secondary side of the coil, but I'd think you'd at least see some sort of spark. Nasty yellow, but something. Apply +12V to one side of the primary side of coil, intermittently ground and unground the other side of the primary. Do you have spark then?
Remove the coil from the distributor and inspect it for cracks.
^ +1
From a variety of no spark complaints I've seen these coils tend to be the culprit. This may be a good place for swapping a part. I would also check the continuity of the rotor and distributor contacts before replacing the coil.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
OK, I pulled out the coil and I see no visible cracks. I'll post pictures of both sides of the coil as soon as I get my camera working. There is a strange pattern on the front of the coil that looks like a waterfall going from the top of the coil directly down to the high-tension terminal, though this more like a surface phenomenon and certainly not any sort of a crack.
Hill8570: Thanks for your idea, but I don't see how I can accomplish your suggestion, as this is an internal coil and I would need to put the distributor cab back on on to test this out, hence I would have no way to ground any side of the primary, unless I am missing something here.
Basically, you're trying to act like the ignitor. Looking at the signal connector going into the dizzy (six pins), the terminal fed by the white-with-red-stripes wire should be @ 12V (the common for both the secondary and primary) and the terminal fed by the black-with-red-stripe wires is the signal from the ignitor, which goes to one end of the primary -- that's what you want to ground / no ground. Just make sure you have the rotor touching the output to the plug you want to observer when you put the cap back on.
OK, I pulled the 2 prong connector off the back of the distributor and found the wires you described (I assume the 4 prong connector in the front of the distributor just stays attached). With the key "on" I have 12V+ on the white-with-red-stripe wire. I have also verified that #1 cylinder is at TDC, put the distributor cap back in place, and attached a spark plug to the #1 spark plug wire.
Now how to proceed. With the 2 prong connector disconnected from the distributor, should I simply extend a jumper from the black-with-red-stripe wire and touch it to ground on the battery and expect to see spark on the #1 spark plug or do I need to apply the 12V to the distributor white-with-red-stripes wire and then apply a ground to the distributor black-with-red-stripe wire (I assume it is the 2nd option, where I apply power and ground to the distributor itself).
Thanks for you continued help.
Eric
Well, you want to keep 12V on the W-R wire however you do it (key "on" is probably the easiest). Then run a jumper from a convenient ground (battery ground / frame ground / engine block), touch it to the B-R (black-with-red-stripes) connection on the dizzy connector and then "untouch" it. At the point you "untouch", you should see a spark. What's going on there is that when B-R grounded, you've got current through the coil primary; when you remove that ground, the current stops, you get a magnetic surge from primary to secondary, and you should get a spark.
Take a look at www.camrystuff.com , Generation 3, "1994 Camry Wiring Schematics", page 73 if you want to see the diagram.
Just wanted to let everyone know that it was the ignition coil causing my no spark condition, which I was able to pick up new from ebay for $30. Thanks for all your help!
