deezee . . .
You might want to read this thread it will give you some insight. Post #19 and #21 get to the point.
Its not an emergency, but it would be wise to get it fixed.
DIY: 1mz thermostat
Off topic - Over heating
Not thats its summer time anywhere - but should any of you end up overheating your car during a time when you need to be somewhere, keep this in mind.
- Turn off the A/C and save the engine / cook the people
- If that alone is not enough, turn on heat to medium. This will give extra cooling and hopefully you make it to your destination.
- If the car is stick shift, don't lug it about it too high of gear. It makes more heat.
- If you know it lost coolant, turn it off, fix the leak and fill it up. There is no substitute for missing coolant.
