Dx,
Here's another thread on the same if you hadn't noticed.
DIY: 1mz thermostat
#19, & #21.
And this one:
Engine never gets warm?
This is nitpicking but . .
Originally Posted by uibalnme
. . . . since the ECU will be constantly spraying more fuel to warm up the engine.
It may add more fuel depending on the actual temp. If it does treat it like a "cold start on a 30degree day" its to make it run smoother and reduce the chance of stalling. This is running the engine rich will cool the engine (too much fuel). While running it lean (not enough fuel) tends to make them run hotter.
As stated, its hard on the cat and if left that way could result in emissions failure, repair bills, ect. Go for drive. Pull over safely off the road and stick your hand near the cat. If roasting hot (above normal, like melting surrounding plastic), it should fixed ASAP. The cat is trying to burn that fuel that didn't get burned in the combustion chamber.
Just for clarification. . .
