1995 5SFE - Change Tensioner With Timing Belt?
I've done a search and have found excellent write-ups for the timing belt and h2o pump replacement. However, the write-ups don't talk too much about the belt tensioner. I can't tell if it is a hydraulic unit or just a simple spring. I can't seem to even find a picture of it - maybe my search skills need serious help. On all the other vehicles I have done in the past, I have always replaced the tensioner, and in some cases the tensioner and idler pulleys. Is that necessary on this job? I want to do it once and be done with it.
On my KIA Sedona DOHC V6, a special tool was needed to tension the pulley after replacing the hydraulic self-adjusting tensioner. Is that going to be the same here?
