OK, are we talking smoke or steam? Different stuff, different smells, different solutions. Does it smell like gas, burning oil, or sweet-ish (antifreeze)?
If the engine was oily and had to be degreased at the garage, the wrencher is correct -- it takes a few days to burn that stuff off.
Smoke (or steam) coming out of the tailpipe when the rig is shut off (assuming it's been run for 15 minutes or so, so it's warmed up) ain't normal. That's worth checking out.
As chronoti sez, it's worth popping the hood to see if you can tell where the smoke is coming from, and see if you can see any large (dripping) leaks.
Otherwise, just keep an eye on your fluid (coolant / oil / transmission) levels to make sure nothing is dropping rapidly, and hang loose.
