99 5SFE 3000+ RPM on Start up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2010, 04:50 PM   #1 (permalink)
View bshirer's Photo Gallery
4th Generation 99 5SFE 3000+ RPM on Start up
I recently rebuilt my 99 camry 5SFE, including an automatic transmission swap. Each time I try to start it, it fires up and the rpm climbs towards redline, where I immediately shut it down. As far as I can tell, all vacuum lines are connected as before. I tried disconnecting the cables to the throttle body, but it had no effect.
bshirer is offline   Reply With Quote
Old 02-08-2010, 05:03 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
sounds like a MASSIVE vacuum leak!
did you use all new gaskets and made sure they were properly tq'ed down?
make sure too the egr isn't directly connected to vacuum
^ and leaving it that way!
Old 02-08-2010, 05:13 PM   #3 (permalink)
All new gaskets used. All bolts torqued to specs.
Old 02-08-2010, 05:37 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Pop off the main hose to the throttle body, and see what the throttle plate is doing during this. Also check to see if the idle air control valve is sucking like a madman (even though I don't think it's even possible to redline the engine using just the IAC air path).
