Schoche Fuse Sucksssss - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2010, 09:34 PM   #1 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
View Bankos66's Photo Gallery
3rd Generation Schoche Fuse Sucksssss
i just bought a schoche 4 gauge pwer wire. and the second i hook it up the damn fuse blows in the cord. SO FKIN PISSED
1994 Camry V6 XLE -- Totalled
1995 Lexus ES300
Bankos66 is offline   Reply With Quote
Old 02-08-2010, 11:58 PM   #2 (permalink)
95 5S-FE
CROYCE992's Avatar
View CROYCE992's Photo Gallery
don't feel bad. It just means that you need a bigger fuse in there. looks like your power draw was more than the fuse can handle. I am blanking out right now but there is a very simple equation that you can use to calculate what size fuse you will need for the amount of power you need for your amp/subs/etc.
4T 6M1 1995 Toyota Camry 5S-FE DX AT Sedan - 171k miles
CROYCE992 is offline   Reply With Quote
Old 02-09-2010, 08:28 AM   #3 (permalink)
View BDOGG001's Photo Gallery
Also,a very good possibility-check entire system wiring for shorts.The fuse,by the way,is doing it's job...protectting the battery... If you have a short somewhere, any brand fuse will "pop"...
BDOGG001 is offline   Reply With Quote
Old 02-09-2010, 10:06 AM   #4 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
Its def the power wire. I just switched to a 4 gauge to get it to fit thru the hole I want to and the fuse in the cord completely burned. So I hooked up the 00 Gauge on the outside(just to make sure I didn't blow out the amp and the amp gets power from that now??) maybe i should buy a bigger fuse for the 4 gauge and how do i know wat size to get?
1995 Lexus ES300
Old 02-09-2010, 03:00 PM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Will fuse blow if the end of power wire is connected to nothing?
What is amp draw of the device(s) you got??
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-09-2010, 03:14 PM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Do you have anything downstream from the power wire to protect the electronics? Depending on the temp rating of the insulation, 4 gauge is good for anywhere from 70 to 95 amps, but you need something downstream of the power cable so your system doesn't blow to protect the fuse
What was the rating of the fuse that was originally installed in the cable?
What sort of power draw are you looking at?
Old 02-09-2010, 06:14 PM   #7 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
I am pushing a 800watt sony xplod amp and it came with a 60 amp fuse. i am going out now before the roads get bad because i called their tech service and they sad i should run out and get a 100 amp fuse. Thats a big fuse
1995 Lexus ES300
