need help on '97 Camry V6 wheels upgrade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2010, 09:42 PM   #1 (permalink)
View pmcom's Photo Gallery
4th Generation need help on '97 Camry V6 wheels upgrade
Greeting.
I've a problem that I need your suggestions. I have a '97 camry V6 and about to upgrade to a new set of 18" rims. When I fit the front rim, the rim spokes touch the brake caliper by approx 1mm. I am now on temporary solution by adding a pair of 3mm wheel spacers. they work fine but I just uncomfortable with them as seem to be some bad stories of wheels breaking loose by using wheel spacers and they also make the wheels a bit out of balance and shaky steering.
I am looking for other options, firstly, change the brake calipers with less width or secondly change brake rotors which have a few mm more width.
Can you please suggest me which brake calipers that narrower and compatible with camry V6 or compatible brake rotors with a few mm more width than the original.
Thank you.
pmcom is offline   Reply With Quote
Old 02-09-2010, 10:06 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
the spacers will work fine and will be safe. many of us use them and dont have problems. i used 5mm ones for a long time and had no issues. there arent any calipers that would be smaller anyways.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
