Need tips to change engine (v6) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2010, 11:50 AM   #1 (permalink)
View popeyethesadist's Photo Gallery
Hi guys I have a 98 Avalon but see that this forum is busier than the Ava. forum so since these are so close to the same I thought I'd pose this here. I have a thrown rod 98 Avalon that needs an engine. Is this going to be easier to come out the top or drop the subframe? Leave tranny attached if out the top etc.? I did a search but everything that mentions "change' and "engine" comes up. Maybe there should be a sticky about engine changes?? I have a painful back so really need whichever way will be easier and less bending. I think if I disconnect steering to come down w/ frame the bottom is best bet but what are ya'lls thoughts? Any tips for both ways? Any one have a thread marked?
popeyethesadist is offline   Reply With Quote
Old 02-11-2010, 12:31 PM   #2 (permalink)
Canyon Killer
View ekopel's Photo Gallery
dude, its really easy...do not bother with the subframe at all... get a cherry picker. I have pulled and dropped the motor in like 8 hours (given I also have done it like 6 times)...
1) Pull off all vac lines, wiring harness, intake (keep lower on)
2) undo pressure plate to torque converter bolts (6 of them)
3) Undo exhaust, belts, etc, etc
4) attach lift to engine (I did this via the lower intake plenum since the engine weighs a total of like 250 lbs...), it is suggested to do it from the rear black bar that is attached to the upper plenum
5) lift up a little...support the tranny...undo tranny to engine bolts, and motor mounts...it should come out really nice...
if you need tips on specifics, let us know, but a manual will help you bigtime...dont bother with the subframe, it will make it more difficult...
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 02-11-2010, 01:04 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
the key word your looking for is "swap", not "change". but hes correct, it is pretty easy if you have an engine lift.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-11-2010, 01:47 PM   #4 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Just curious: how much is the simplest engine lift? Is it possible to rent it somewhere?
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 02-11-2010, 01:57 PM   #5 (permalink)
the cheapest lifts are about 200 bucks. They can usually be rented also from like A-1 rentals or the like. I have one already luckily. I also have an A-frame to just lift the body of the sub-frame. I was kinda worried because it's sometimes there's not enough room to pull engine far enough away from tranny to clear coming up. Would it help to pull harness out completely from ECU and keep on engine?
Old 02-11-2010, 01:58 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
I think pep boys usually has one for a regular price for around 200
when it's on sale, it's about 100
HaHa
Old 02-12-2010, 05:07 AM   #7 (permalink)
when I search "swap" I get all kinds of results for people wanting to upgrade to a bigger or more pwerful engine, not a simple change-out. The manual suggest pulling transaxle w/ engine/ which is easier?
