Well, I paid some neighborhood kids to shovel out my car. Big mistake. I guess they got pretty enthusiastic and decided to use a metal shovel on my car....
So since I need to get it redone, I was thinking of going for something a little different. Anyone have any suggestions? I want something different, but not too distracting.
If you take it off, you'll see the two stripes forever where the paint UNDER the pin stripes hasn't been faded by the sun, whereas all the paint around it has been. Advance and autozone sells pinstriping tape. Just get some black in the smallest thickness you can find, and if it's still too thick, cut it. It might be tedious but as usual, the more time you spend and the more precise you are, the better it will turn out.
If it's just that one spot, and you have steady hands you COULD try to just pinstripe it with paint.
I'd try to find stripe tape that's close to the same color and try a patch job.
Clean cut both ends on the car, trim the new tape to length and width to match the old stripe.
Might be able to make a seamless repair to it depending on how much time you put into it.
That's what I'd try first.
If it doesn't work out, I'd clean it off and see how it'd look without the stripes, if there isn't a noticeable tan line.
Then as last option, I'd put all new stripes.
Thanks for the suggestions guys. I am an art major after all so I guess I should try to repair it myself and save some money. I have to do tedious precision cutting/painting/sticking and drawing straight lines enough anyways.
If that doesn't come out right then I'll go to a pro.
In the meantime I'll probably remove the striping on the doors it's damaged and if I like how it looks without it (assuming the fading isn't too noticeable) I may even decide to de-stripe the car!
is it down to the metal? if so id clean and cover that up ASAFP. all this salt will start to eat at the metal quick. best paint jobs ive seen were actually from eyeball96's neck of the woods. this painter did some work on my car and repainted Joes car. looks amazing.
There is one spot on the edge of the trunk that is all the way down to the metal.
I've got some touch up paint ill try to fix it soon. Once the weather gets a little warmer.
thanks bigbird, i might have to contact you and get the painter's contact info from you sometime. once i have money again after I supercharge my car lol, so... like ten years
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
