Mounting Gen 3 taillights on Gen 3.5????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2010, 03:12 PM   #1 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
How the hell do you mount these lights on the inside of the light? (closest to the panel) On the gen 3.5 there are screw mounts that you screw a nut onto, the gen 3 clear/red lights i just got, they just have holes....
any ideas? I know people in here have gen 3.5 with these Red/Clear lights on....
here are some pics
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Old 02-12-2010, 05:17 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
hu? IIRC they mount from the inside not on the outside. there are long studs that protrude from the back of the light and you screw thoes down through holes in the trunk. i never remember seeing any holes on the sides of my lights.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-12-2010, 05:26 PM   #3 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
The only thing I dont like is that the lights dont match the contour of the center panel. The only way to do that is to get the gen 3 center panel. Although I like the gen 3.5. Thats why I did the swap. Also Bigbird is right. There are two 10mm nuts on the inside of the trunk behind the carpet. They will remove the little piece with the two screw heads on it. Hope that helps.
4Cyl'erThriller is offline   Reply With Quote
Old 02-13-2010, 12:28 AM   #4 (permalink)
I know it doesnt mount on the outside of the light. The problem is there are no bolts on the light, I just have holes on the light in the spot that is kind of close to the holes on the body of the car. Im not sure what I need to do. Do the screws come off the gen 3.5 lights? I dont see how that would work anyway because the holes on the lights do not match up to the holes on the body. its very strange to me....ive seen these lights on gen 3.5s before, i dont understand how these would be any different.
340,000+
Old 02-13-2010, 08:36 AM   #5 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
I was just about to switch to an SE panel, but I guess I won't.. didn't know the center panels are different shapes between 3.0 and 3.5
iovaykind is offline   Reply With Quote
Old 02-13-2010, 09:07 AM   #6 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
I didn't find it that difficult to switch to the red/clear tails, and SE panel...
and CF trunk...
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 02-13-2010, 09:13 AM   #7 (permalink)
iovaykind's Avatar
But I only wanted to switch the center panel! Though, I do like the 3.5 center panel, its just that I have to bondo and paint it over cause of the camry peg holes..
Old 02-13-2010, 09:32 AM   #8 (permalink)
uibalnme's Avatar
Well, if you do, the gen3.5 tail lights will stick out farther at the bottom than the SE panel. Obviously, the opposite is true for gen3 tail lights, and a gen3.5 center panel. The only way it will look right(up close anyway), is if all the parts are from the same generation. Otherwise, if you're within ten feet of the car, you'll be able to spot the inconsistencies in the lines between the bottom of the lights, and center panel.
Old 02-13-2010, 10:17 AM   #9 (permalink)
and CF trunk...
I know it's not hard, I just thing Im missing some bolts or something. Did u get new bolts to mount them? Or did u take bolts off the gen 3.5?
340,000+
Old 02-13-2010, 11:10 AM   #10 (permalink)
Gameroom cash: $368576
View RichieRichJP's Photo Gallery
If you took the OEM tail lights off, then there's no reason for you to not figure out how to put aftermarket ones on.
RichieRichJP is offline   Reply With Quote
Old 02-13-2010, 11:12 AM   #11 (permalink)
93 Camry LE 5S-FE
Im pretty sure the piece with the two bolts should be able to be removed from the OE lights. Just swapped over to gen 3.5. from gen 3. Everything was pretty plug n play. I cant imagine it would be much different than OE. Depo wouldn't mass produce something for a Camry that would take any sort of serious modification for installation.
Old 02-13-2010, 02:43 PM   #12 (permalink)
I HAS BOOST!!!
bigbird's Avatar
im almost willing to bet they've been broken off. take a pic of the back of your OEMs and the new ones.
R.I.P.
Car Domain:
Old 02-13-2010, 05:17 PM   #13 (permalink)
Here are the pics of the lights...i should have done this first anyway....
Gen 3 on top, Gen 3.5 on bottom
Gen 3.5 broken up top, leaking which is why i got these clears anyway. The screws are on the right, but they are coming from the housing, i do not believe they come out.
Gen 3 back, notice there are no screws on the right.
Front of each.
I do not believe im retarded....haha there has to be a bolt missing or something
340,000+
Old 02-13-2010, 07:49 PM   #14 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
something is DEFINITELY missing. wtf...
'07 Honda Ruckus Big Bore
Old 02-13-2010, 10:07 PM   #15 (permalink)
I HAS BOOST!!!
bigbird's Avatar
shit looks like something might have been broken off on those gen3 ones, top right of that pic. id confirm that but my trunk cant open so i cant remove mine.
R.I.P.
Car Domain:
