1995 Camry V6 A/T issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2010, 03:19 PM   #1 (permalink)
The TN Community Sucks
SnoFox4's Avatar
View SnoFox4's Photo Gallery
Unhappy 1995 Camry V6 A/T issues
Hi,
I know I've posted about this before a long time ago, but since then I've learned that the O/D light is flashing due to a torque converter problem.
'95 V6 A/T w/ 194.5K miles.
I had the trans fluid changed 1K miles ago, and it's actually shifting worse.
The car used to have very smooth shifts from 2-3, and 3-4. But now it bumps into every gear and when I hit the gas it doesn't downshift + the RPMs go way up while the car is accelerating (without downshifting). I've also noticed that when I coast the RPM's drop about ~1-2K when I release the pedal.
Is this all due to the torque converter?
Thanks,
Sno.
SnoFox4 is offline   Reply With Quote
Old 02-12-2010, 03:24 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
What's the DTC (code) that you're getting?
Old 02-12-2010, 03:38 PM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
When the ECU detects a fault the flashing O/D light is displayed and T/C lockup is disabled. That explains the RPM drop while coasting.
The engine rev when you nail it sounds bad though. What's the fluid look and smell like? Does it smell burned? Is it brown?
How many miles ago did the light start dancing? What kind of driving does it get?
I'll take a wild stab and GUESS that you looked up the error code the first time and it was for the torqure converter not locking up? yes, no?
If it was t/c one way clutch (sprag clutch), she may be done. Stop the damage and get a new t/converter or fry the whole trans. . .
^+1 need the old and new error codes.
73sport is offline   Reply With Quote
Old 02-12-2010, 04:36 PM   #4 (permalink)
SnoFox4's Avatar
I'd like to say that I drive the car pretty nicely, mostly city miles though, and occasional on-ramp WOT while trying to merge in front of a semi.
I'll go check the fluid when I check the DTC, which pins do I hit to put it into diagnostic mode?
I can't recall the actual code it had, so I'll check it again.
EDIT: The fluid is slightly brownish but mostly red, and smells fine.
Old 02-12-2010, 05:03 PM   #5 (permalink)
hill8570's Avatar
IIRC, the '95 V6 was OBD II, so you have to use a code reader...you can't just jumper something and read the blinking lights.
Old 02-12-2010, 05:07 PM   #6 (permalink)
SnoFox4's Avatar
There is still the OBDI diagnostic thing under the hood though? I have an OBDII reader, but I don't think it will work with that connector.
Car was built in 06/95.
Old 02-13-2010, 11:36 AM   #7 (permalink)
SnoFox4's Avatar
I found out from my sister (the previous owner) that the car has a bad T/C lock-up solenoid and has had this problem for about 20K miles.
Old 02-13-2010, 11:53 AM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
IIRC, the law requires that an OBD-II connector be within 1 ft of the steering wheel column. So if you see a connector under the hood, it's the standard diagnostics connector (the kind where you jumper things like Tc1, E1, FP, etc). You'll also see an emissions label under the hood. It should say "OBD II Certified" or something like that.
Old 02-13-2010, 12:00 PM   #9 (permalink)
Your local parts store may offer free code reading service. So you might want to make use of that. Sometimes the lock-up solenoid may be because of faulty wiring. So you kinda have to check the solenoid before replacing it.
Have you ever dropped the pan to wipe clean the metal sludge? I'd change out the strainer as well, because the old gasket may become brittle and cause a suction side leak.
What type of ATF was used? You might want to try a High Mileage ATF that's GM Dexron III compatible, for example, Valvoline MaxLife ATF. (D-III name is no longer licensed, so you'll find only "D-III compatible". I wouldn't use the thin Dexron VI.)
http://www.valvoline.com/products/br...ssion-fluid/37
Old 02-13-2010, 12:35 PM   #10 (permalink)
SnoFox4's Avatar
The only other diagnostic port is a circular one underneath the dashboard.
I'm sure that it hasn't been dropped and cleaned, but I feel like it's so worn at this point that a rebuild will be required by the next fluid change.
Old 02-13-2010, 12:51 PM   #11 (permalink)
Hmmm, Autozone's free repair guide suggests OBD-II's D-connector for that year. Oh well.
But if it's OBD-I then follow the directions on AZ and jumper some connectors to see the MIL light flash the error codes.
