Steering issue! Might be dangerous?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2010, 01:32 PM   #1 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I recently got my transmission rebuilt in my 93 V6. Since having it back, I got the alignment done because the steering wheel was not straight when I got it out of the shop. In fact, they told me when I picked it up from the transmission shop that I need to get it done because the steering wheel was not straight.
I noticed yesterday while driving that the steering wheel was way off center again. So my wife and I kept watching as I took corners. It would constantly go back to different spots when the car was going straight! There HAS TO BE something loose, but I have NO idea what it could be.
Could ANYONE shed some light on this!? Any suggestions as to what I should check to make sure everything is tight?
Thanks for any help!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 02-13-2010, 02:19 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
might be a loose steering rack, where did you get your alignment done? my rack was loose and i took it to toyota and they notice they couldn't get the aligment right and found the problem for me and fixed it for free (just tighting bolts but still)
but tho i just came back from the dealer for this and the wait time is REALLLY high (recall nonsense).
also theck the control arms and tie rods are nice and tight, you can take it back to where you had the aligment done and have them check and do it right.
^ and leaving it that way!
Old 02-13-2010, 02:19 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
so you have taken it in for an alignment?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-13-2010, 02:25 PM   #4 (permalink)
Yes, the day after I got it back from getting the tranny rebuilt, I got it aligned. It wasnt pulling one way or the other when I got it from the tranny shop, but the steering wheel wasnt straight.
So you think I should take it to the tranny shop or the alignment shop?
Old 02-13-2010, 08:53 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If things went south after you got it back from the shop, then I'd check the tightness of the steering rack as suggested. The shop probably drop the transmission from the bottom, and if so they loosened the engine cradle and steering rack. They also loosened the left axle. If they didn't use a torque wrench then I personally don't know how they'd get the axle nut right.
Put the front end on stands and see if you can detect any free play at the wheels (12-6, 3-9 o'clock). In addition to that, do the standard check of ball joints and control arm bushings, bolts, engine cradle bolts (wheels on the ground), etc.
Old 02-15-2010, 06:18 PM   #6 (permalink)
Took it back to Firestone today and they told me that the steering rack bolts were not tightened completely. This wore out the bushings on the rack, so not they have to be replaced. I had them document all that and i called the transmission shop and they said they would fix it. Im taking it to them in the morning and dropping it off. HOPEFULLY, this will be the last time.
Old 02-15-2010, 06:49 PM   #7 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
Glad that they will take care of it for you!.....I have a 1993 LE V6, in great shape with 115K miles! I will be happy as a clam if I make it to your 237xxxK miles.....
ricamryman is offline   Reply With Quote
