gen 3 drum to disc - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2010, 02:50 PM   #1 (permalink)
stlwil's Avatar
View stlwil's Photo Gallery
3rd Generation gen 3 drum to disc
I have a 95 l4 w/o abs. I have everything but the backing plate and parking brake assly. dois it matter if the backing plate and parking brake assly comes off a car w/abs?? l4 or 6?? if i use 1 from an abs car do i just cut the wire? thanks
stlwil is offline   Reply With Quote
Old 02-13-2010, 03:46 PM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
Gen 3 and 4 Rear Drum to Disc DIY
it doesn't matter your just swapping over. the hub would be different that's all. no abs parts are on the rear discs at all.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 02-13-2010, 03:54 PM   #3 (permalink)
stlwil's Avatar
so the abs wire does not haveanything 2do with the parking brake. i didnt look close enough i geuss. it looked like it was going into the backing plate? so the wire goes into the hub??
Old 02-14-2010, 08:58 AM   #4 (permalink)
Mad Scientist
all you need is the backing plate rotor and caliper assembly.
the hub and knuckle has the abs parts on it, those you don't need.
Camry Wagon Crew
Old 02-14-2010, 09:57 AM   #5 (permalink)
stlwil's Avatar
Talking
thanks
Old 02-14-2010, 03:35 PM   #6 (permalink)
Toyota 4 Life
TravisAe86's Avatar
View TravisAe86's Photo Gallery
I have a question also....
I want to get rid of the rear drums, is the process of going from drum to disc a simple task? Would i run into any issues during the process?
Thanks
TravisAe86 is offline   Reply With Quote
Old 02-14-2010, 05:39 PM   #7 (permalink)
View Kenny_McCormic's Photo Gallery
Whats with the hate on rear drums?
Every time something little breaks on my car, the lulz level of driving it doubles.
Kenny_McCormic is offline   Reply With Quote
Old 02-14-2010, 06:00 PM   #8 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
It's a pretty simple task, travis. The only thing you might run into is some rust on some of the screws/bolts holding some of the exhaust heat shields on. nothing major. I saw you posted on the DIY thread. Ask me if you need anything.
Kenny- rear disks are more efficient than drums and perform much better. The 5S didnt get them because of less weight and power when compared to the 1MZ sedan/wagon/ES300, but it does see an improvement from a rear disk upgrade.
'07 Honda Ruckus Big Bore
