1998 Camry dome light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2010, 09:07 AM   #1 (permalink)
View ssmith1347's Photo Gallery
I have a 1998 Camry that I have had to replace the dome light bulb every 1-2 months. I have checked voltage. Used different brand bulbs. Had the dealer replace it, all with the same results. This has be going on for approximately 2 years. Please help if you have experienced a similar problem.
ssmith1347 is offline   Reply With Quote
Old 02-15-2010, 11:19 AM   #2 (permalink)
View ruggz's Photo Gallery
Check the fuse for the dome light be sure you have the right amp in there.
ruggz is offline   Reply With Quote
Old 02-15-2010, 11:39 AM   #3 (permalink)
View hzt30's Photo Gallery
Intermittent short?
Could be an intermittent short. Have you checked the amount of CURRENT GOING THROUGH THE CIRCUIT?
hzt30 is offline   Reply With Quote
Old 02-15-2010, 11:56 AM   #4 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Check yer contacts and make sure everything is tight. Sounds like a loose wire is spiking the power...probably the ground.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 02-15-2010, 12:03 PM   #5 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Has there been an aftermarket alarm installed? Or anything else that has been tapped into the door trigger switches that would affect the dome light circuit??
#2! is offline   Reply With Quote
Old 02-15-2010, 01:39 PM   #6 (permalink)
View Lightning Blue's Photo Gallery
I'd say a bad switch somewhere!
2001 Camry LE - I4 - 138,xxx miles
2005 Neon SXT - 47,xxx miles
Lightning Blue is offline   Reply With Quote
