1999 Camry Bad Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2010, 05:04 PM   #1 (permalink)
View BennyO2367's Photo Gallery
Hello everyone, new to the forum (or at least to posting),
I had my timing belt, water pump, and thermostat done by a local shop last week. I bought all the parts with the exception of the water pump from Toyota. I drove the car for the last 2 days, and I noticed this morning a large amount of oil on the drive, I backed it out and parked it in the lot next door and there was a good puddle of oil under it again. I checked the oil and it was about a quart low, I added it and parked it back in the mechanic's lot. My friend owns the shop (it is a reputable shop), and like a typical mechanic he is telling me it is probably no big deal, easy to say when its not going to be at his cost (assuming they did not screw up). I am not all that familiar with the timing belt set up along with all the seals, is it possible that one of the seals was improperly installed and it has resulted in a major oil leak? It is definitely coming from the timing belt lower cover area, or at least it looked like it from above. It is pretty cold here and I didn't want to get under it, the power steering rack is covered in oil, especially the boot area. It is a 99 CE with a 2.2L. 140,000, 2nd timing belt change. Have never had any other issues and I keep up with the general maintenance myself.
Thanks,
Benny
BennyO2367 is offline   Reply With Quote
Old 02-14-2010, 06:39 PM   #2 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
It's probably a seal that was not installed/tightened correctly. I hope you were able to "mop" up the spilled oil before it is washed into the storm sewers
zythr is offline   Reply With Quote
Old 02-14-2010, 07:10 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Generally, when you change out the timing belt & water pump, you should change out the camshaft, crankshaft, and oil pump seals at the same time.
Sounds like when they were in changing the timing belt, they knocked one of the seals askew.
Old 02-14-2010, 08:56 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
I don't know how any shop couldn't do an oil seal right. An improperly installed oil seal can do that. But PS rack is relatively far back, so I wonder if the valve cover gasket is leaking too (down the back of the engine, so use a flash light/mirror).
Old 02-15-2010, 12:28 PM   #5 (permalink)
That's easy. They want to get the work done fast, so they can go on to the next vehicle, In other words, try to work on as many cars as they're open, which translates into more money.
Old 02-15-2010, 03:00 PM   #6 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation
What are you, some kinda tree hugger?.......Geez!.....
ricamryman is offline   Reply With Quote
Old 02-15-2010, 05:22 PM   #7 (permalink)
View murphymp's Photo Gallery
And what are you, someone who likes his ground water polluted? Geez!
murphymp is offline   Reply With Quote
Old 02-15-2010, 06:00 PM   #8 (permalink)
Why? Is there something wrong with that?
Old 02-15-2010, 06:07 PM   #9 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Not to further the off topic genre of this thread, but what's wrong with being concerned about oil spilling into our water supply?
Chris Crash is offline   Reply With Quote
Old 02-15-2010, 06:24 PM   #10 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Nothing, however, oil is nonpolar and water is polar so they are immiscible. So as long as the water is treated, there is nothing wrong with it. There is a problem though with oil spills being on wildlife because oils can enter their body much like DDT does.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 02-15-2010, 06:42 PM   #11 (permalink)
Would you drink water that had oil sitting in it?
Old 02-15-2010, 06:49 PM   #12 (permalink)
Chemist at Chevron
HAHA, well next time you drink water or eat food, try not to think what people or animals have done to it.
95 Camry LE I4 195k
Old 02-15-2010, 06:52 PM   #13 (permalink)
View Boston Redneck's Photo Gallery
There are actually 4 seals behind the timing cover that need to be changed. The crank, cam and oil pump seals but there is an inner oil pump seal (we call it the spaghetti seal) that gets very dry and cracks.
I agree with most everybody else here that who ever did the job probably installed it wrong and the lip is folder over or it is askew.
Boston Redneck is offline   Reply With Quote
Old 02-15-2010, 06:54 PM   #14 (permalink)
No concern about this being off topic, it is relevant. This member has a big oil leak that not only left a puddle on his garage floor, but also on the ground of the lot next door. The rain, snow, etc can come and wash this oil into the sewer if it is not cleaned up, hence the concern for it being cleaned up. Leaking oil from vehicles can be a big problem in more ways than one, regardess of make or model. Besides, he's "wasting" money having to refill because his oil level is low
Old 02-20-2010, 10:06 PM   #15 (permalink)
View MickyB's Photo Gallery
Good god people! We all love our precious mother earth and blah blah blah, so lets move on to topic.
MickyB is offline   Reply With Quote
