Ignition/MPG issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2010, 01:34 AM   #1 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Ignition/MPG issue
What I did: replaced my stock spark plug wires (Sumimotos) with NGK ones, seafoam brake booster and gas tank --> MPG dropped dramatically (dont have a numerical value since I didnt pump up) What I did today: Put back my stock spark plug wires --> went 40 miles, the rate of the needle dropping is less What could be wrong? BTW, I have bosch plugs, still going strong after 47k. Things that I think that might be wrong: bad wires, plugs corroded, O2 sensor fouled
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 02-15-2010, 02:36 AM   #2 (permalink)
View llcoolpass's Photo Gallery
less compression
vacuum leak
all in your head
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
Old 02-15-2010, 11:56 AM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Check the resistance of all the new wires and all the old wires. Assuming it's not just in your head (I don't trust any MPG data that isn't fill-to-fill), the NGK wires might have resistance that is too high for the Botch plugs. High resistance=weak spark=bad mileage. May have also fouled your plugs running that Seafoam crap through your system, but that would effect both sets of wires equally.
Old 02-15-2010, 01:57 PM   #4 (permalink)
Chemist at Chevron
Sorry, I'm not very literate when it comes to electronics. I tested my NGKs. My multimeter is set at 200K. #4 is 3.2, #3 is 4.6, #2 is 4.7, #1 is 5.8. Looking at the manual, it says the cords should be 25K ohms or less, so I dont think the wires are bad. I was looking at the NGKs connection to the plugs and noticed they have a smaller surface area than the sumimotos. Could this be to blame? I havent checked the resistance of my stock wires yet.
95 Camry LE I4 195k
