I agree with previous posted.
step 1. purchase ECT and replaced...if the problem went away, u fixed.
step 2. if ECT did not fixed your problem, now remove distrubutor's cover to see ignition coil (ignition coil look flat). if the ignition coil goes bad, it's very hard to crank when the engine is hot. you can crank when its cold.
I am more believe his ignition coil inside the distributor went bad. if you remove the distributor, please make reference on distributor bold that hold the distrubutor.. it'll be easier when you reinstalled.
