Originally Posted by silkydraws
I ask because I've been told it had to be to be a 2003 Camry engine but it sure doesn't look like it to me.
That's just to cut down on gear noise as the gear set has free play which makes noise. A zero mesh quiet gear can't be had AND keep the parts from destroying each other as it goes through temperature cycles with everything expanding and contracting.
The drive gear with the split contact surfaces has a spring inside which rotates the two split gears apart giving a lash free quiet gear drive when engaged with the driven gear.
Probably not the best explanation but not VVT. Just quieter gears.
That is one CLEAN MZ. Never seen one so spotless!
Hindsite says SCARY CLEAN! If I'm not mistaken it has rust on it like it was pressure washed or hot tanked recently. Find out MORE before you buy it. Look for water in the oil, PVC, pan, anywhere you can get access to look for moisture.
