94 to 96 1mz-fe differences - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2010, 07:21 PM   #1 (permalink)
View casey38boost's Photo Gallery
I have a 96 lexus es300 w/ the 1mz-fe, had an oil pump failure, rod knock now.
I also have a 94 v6 camry with 1mz-fe as a running parts car.
I am going to swap the 94 motor into the 96 es300.
Is there anything that is not interchangeable to the cars? or can I just yank the motor/trans with wiring harness attatched and use the 96 ecm?
thanks
casey38boost is offline   Reply With Quote
Old 02-16-2010, 07:25 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
i believe youll have to swap the whole thing, ECM and all. the 94 uses a slightly different ignition system that i dont think is compatible with the 96.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-16-2010, 08:08 PM   #3 (permalink)
Ok, i will look into it, or if anyone has a definate answer its appreciated.
Also is it reccomended to pull the engine/ trans from the top? or out the bottom?
Old 02-16-2010, 10:32 PM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
you can use the entire engine but not the plenum and the wiring. besides that the motors are identicle.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 02-17-2010, 01:45 AM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
the plugs and coils counts as wiring
94 cop (6 coils)
96 wsi (3 coils)
^ and leaving it that way!
Old 02-17-2010, 09:57 AM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
Differences:
- the 94 uses a hydraulic fan system that runs off the p/s pump whereas the 96 uses an electric fan
- This may be the biggest problem, as you can't just swap the pumps over because they fit differently on the motors and the pulleys won't line up with the crank
- BUT what you can do is either plug up the extra hose line AT the pump that was designed for the fan, or reroute it so that it just goes back into itself
- the 94 uses a different ignition system - 6 coilpacks vs 3 coilpacks (but this can be swapped entirely)
- the 96 uses a different iac/electronic system - but you should be able to go around this by swapping the plenum (though, may not need to do this) or just the throttle body
So, theoretically it should work since the block is the same....BUT....during my swap, a 95 motor into my 94, there was one extra plug on the 95 harness that my 94 didn't have....and I couldn't figure it out... in my case, it didn't matter since I didn't have the sensor (whatever it was) anyway...but if you're going backward, you may be missing an additional sensor that wasn't designed to be on the 94 block
but as said as well...you can't do a direct swap since hte electronics are very different between the 94 and 06. At the very least, you'll ahve to swap the engine harness and then some other little things
HaHa
The Following User Says Thank You to Eye8Pussies For This Useful Post:
Nervous (03-10-2010)
Old 02-17-2010, 02:47 PM   #7 (permalink)
Thanks for the info.
Looks like i will just use everything from the 94 including coils, intake, ecm, power steering and radiator.
I am just hoping that it will pass the obdII inspection to get a sticker. I think the 94 is obdII ready it has the same port as the 96 so i think it will be OK
Old 02-17-2010, 04:50 PM   #8 (permalink)
TN Pussy Man
the 94 is obdII compliant
only thing that you may have to worry about is if the ecu works well with the dash harness as well, but for that...I would just splice as needed instead of swapping the dash harness (if needed)
HaHa
