94' Camry hesitates under load!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2010, 09:51 PM   #1 (permalink)
View turbohawk's Photo Gallery
I have a 94' camry 4 cylinder. I have replaced the plugs, wires, coil, NGK plugs (.043) cap, and rotor. I have also checked the timing which is 5 degrees without jumper, checked the ECT ( is good). The car idles fine and drives fine until it gets under load then it hesitates like its missing. What would the most likely problem be in this situation?
turbohawk is offline   Reply With Quote
Old 02-19-2010, 11:09 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
The problem is more than likely the fact that it's a camry and it's (I'm assuming as almost all are) automatic.
Chris Crash is offline   Reply With Quote
Old 02-19-2010, 11:35 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
missing isn't normal. check timing again with jumpers, then seafoam the engine to make ure of no carbon spots
^ and leaving it that way!
Old 02-20-2010, 02:57 AM   #4 (permalink)
View llcoolpass's Photo Gallery
you didn't replace the ignitor?
what do the spark plugs tell you??
potato muffler syndrome[ie clogged cat]?
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
Old 02-20-2010, 05:01 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
try using higher octane gas and see if it still misses, if it doesn't, then it may just be carbon deposits in the combustion chamber raising the compression, and you might be able to clean it out with seafoam
if it doesn't help, then start looking elsewhere for the problem
HaHa
