I feel justified - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2010, 03:17 PM   #1 (permalink)
View Novice_cardude's Photo Gallery
I feel justified
Well, a few months ago I did a full timing belt job on my Camry, spent around $400 on parts. It didn't run any different, but I replaced a lot of parts to keep 'er going.
Today was my next scheduled oil change. I once again spent money on other parts that needed replacing. This time it was only $200, but I replaced the front and rear motor mounts (the front one was demolished), and the left axle. I got a transmission mount, but surprise surprise it was for an automatic, so I have to get the proper one Monday. But for once driving around after that service, I felt justified for spending that money.
It's a lot easier to start smoothly and shift without jarring the car when the motor holds still during said operations. Also when I turn right I no longer hear that annoying clicking sound. Also, the clutch pedal and gas pedal were squeaking during operation. I did my own Toyota gas pedal recall service involving a can of white lithium grease, so that noise is gone. In short, I spent half as much time and money on this service, and there's a noticeable difference driving the car.
I still have an exhaust leak to fix, but I need to find a replacement flex pipe to do that...
I had been dealing with loose motor mounts for so long, that just that simple repair made a huge difference. Now I just want to go out and drive just to drive. It's been a long time since I've wanted to just drive my Camry.
Has anyone else had that before, where you put off a repair, then when you finally do it, it's like getting a new(er) car?
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 02-20-2010, 05:52 PM   #2 (permalink)
View L-Burna's Photo Gallery
1994 Camry 3VZ-FE 152 k Miles
1991 ES300 3VZ-FE 108 k Miles (1992 Shape)
L-Burna is offline   Reply With Quote
Old 02-20-2010, 06:19 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
indeed, most people call it satisfaction!
rusty9 is offline   Reply With Quote
Old 02-21-2010, 11:41 AM   #4 (permalink)
View Judge2's Photo Gallery
front motor mount.
Thanks for the sharing the experience on replacing the front motor mount. I believe mine should be replaced, and I have put it off. A report like yours motivates me to do it.
Judge2 is offline   Reply With Quote
Old 02-21-2010, 06:33 PM   #5 (permalink)
Yeah, it definitely makes a difference just replacing the front mount. The rear mount was OEM so I replaced it even though it wasn't as bad as the front one.
The front mount moving around generally pops the upper 'dogbone' mount, so plan on getting both. The dogbone takes like 2 minutes with a 14mm wrench, and the front mount can be done with basic sockets and a floor jack.
'96 4cyl 5spd Camry
Old 02-21-2010, 07:18 PM   #6 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Yes. Or when you do performance upgrades that transform how the car feels/handles, and you just can't drive it enough.
BlueFusion6851 is offline   Reply With Quote
Old 02-21-2010, 07:21 PM   #7 (permalink)
View mr_kabo's Photo Gallery
Nice job man, congrats. Thanks for sharing this.
Be simple and give your best...That's it...
mr_kabo is offline   Reply With Quote
Old 02-22-2010, 03:53 PM   #8 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
now there is a happy man
now, flex pipes are easy to fix, just go get one from any auto parts store that is 2" in diameter and go to a exhaust shop and have them cut the old one out and weld the new one in. should be a $40 dollar fix
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 02-22-2010, 07:36 PM   #9 (permalink)
I gots me a Lincoln Electric mig welder with gas, so the weld itself would be free
Plus dropping that section of exhaust will make it easier to remove and re-seal the oil pan, which I have to do anyway. Kinda looking forward to the end result of that repair. No more angry bumblebee sound!
'96 4cyl 5spd Camry
Old 02-23-2010, 12:25 AM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
nice
grats!
