RS3000 Alarm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2010, 11:04 AM   #1 (permalink)
View ghost111's Photo Gallery
RS3000 Alarm
Where is the RS3000 ECU located on the 1999 Camry. I looked under the seats, not there???
I need to program a secondremote.
ghost111 is offline   Reply With Quote
Old 02-21-2010, 11:13 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
It should be located left of the steering wheel. On mine you have the little led indicator "box", its located behind that. Remove the coin tray and pop out one of the rectangular slots next to the indicator. You should then see a green button you press with a pen.
Took me forever to find it.... Mines a dealer installed one but they should all be in the same spot.
carsrus is offline   Reply With Quote
Old 02-21-2010, 11:59 AM   #3 (permalink)
OK so it's behind the red indicator light......I will check.
Thanks
Old 02-21-2010, 08:49 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
in my '00 Camry Solara the alarm ECU was located under the central arm rest. I had to unbolt it and remove to see the RS3000 VIP ECU. generic Camry may have a different location of RS3000 ECU.
Old 02-22-2010, 02:45 PM   #5 (permalink)
Thaanks
Can you tell me the approx size of this ECU I see something tucked back in there that is greyish in color and about 4"x3"x1" + or minus. I am going to have to remove the lower panel to get at it.
THX
