1992 Windom play in steering about centre - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2010, 06:36 PM   #1 (permalink)
View L-Burna's Photo Gallery
hi guys,
i just got the windom and noticed that it has quite a lot of play in the centre of steering, as in when i steer straight ahead i have to turn it (steering wheel) quite a lot before it turns...!?! is this like a worn component or just how it is? Its COMPLETELY different to the camry. thanks in advance for any input
1994 Camry 3VZ-FE 152 k Miles
1991 ES300 3VZ-FE 108 k Miles (1992 Shape)
L-Burna is offline   Reply With Quote
Old 02-22-2010, 07:17 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
id say really worn out tie rods or the rack is loose
rusty9 is offline   Reply With Quote
Old 02-22-2010, 07:59 PM   #3 (permalink)
cheers, will look into it.
Old 02-23-2010, 08:20 AM   #4 (permalink)
rusty9's Avatar
sorry, an easy way to check the tie rods for play is to jack up the front and grab the tire at 9 and 3 oclock and wiggle. you would feel excess movement with the steering locked. if you can, watch the tie rod itself, to see if the play is coming from inside the boot (inner tie rod) or at the end where it meets the knuckle(outer, and easier to DIY)
