exhaust leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2010, 09:32 PM   #1 (permalink)
View 97vulcan's Photo Gallery
3rd Generation exhaust leak
I've got an exhaust leak now that just seems to get worse. I'm guessing it's the flex pipe, as it looks like it's been welded over and over near the front of the flex pipe. Is this an expensive part? and if I could get someone to weld it for me, would it be pretty straight forward?
Thanks,
Adam
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
97vulcan is offline   Reply With Quote
Old 02-22-2010, 10:56 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i paid $150 for flex pipe repair at local muffler shop. they need to weld the new one in place. not a big deal. it takes 15 mins to get it done.
although flex pipe can brake also because of bad/worn engine mounts on bottom of engine you should inspect all of them closely (front mount, rear mount, top rod and the transmission mount). they may need replacement as well. if one of them goes then there is a good chance all of them are in bad shape.
Old 02-23-2010, 08:00 AM   #3 (permalink)
View kei_kusanagi's Photo Gallery
Also just a heads up, that one thingy on the flex pipe that looks like stitches, make sure you get a new one because you really cant tell if it's also leaking or not until you actually use it. Mines leaking and it sounds like a muscle car but there is no tears that I can see. @_@ need to replace it.
kei_kusanagi is offline   Reply With Quote
Old 02-23-2010, 08:45 AM   #4 (permalink)
View ShawnD93Toy's Photo Gallery
lol you paid 150 for just the flex part? wow, some shops are scam artists.
http://cgi.ebay.com/ebaymotors/Magna...ht_3913wt_1035
And bosal also makes OEM replacements, I have their replacement for my v6 front pipe. Not the cleanest welds but they are solid.
Amazon Amazon
If you know a good mechanic personally you can also get cheap labor on the install
ShawnD93Toy is offline   Reply With Quote
Old 02-23-2010, 09:06 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah that's what i paid for part & labor with 1yr warranty.
Old 02-23-2010, 09:14 AM   #6 (permalink)
I think I ended up paying 200ish for the front pipe on my v6 and labor, my friend gives me good pricing lol Big al's wanted 700 just for the front pipe, bunch of scam artists.
Old 02-23-2010, 01:26 PM   #7 (permalink)
View hdninja's Photo Gallery
i got mine fixed on a 99 camry 4cyl at a local shop for like 70-80 dollars. so deff dont pay more than 100
hdninja is offline   Reply With Quote
Old 02-23-2010, 01:56 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
hmmm, need to re-check the bill, not sure 100% but maybe there was also something else on it. will post back after work. if they charged me double for that I won't go there anymore.
EDIT:
so the total bill is for $200 and it's the flex pipe and A/C check which was done at same time. though i'm pretty sure they mentioned $150 for a flex pipe alone...
Old 02-23-2010, 05:27 PM   #9 (permalink)
Whatever you do just don't patch it, they don't last at all and it is just poor thinking.
Old 02-23-2010, 07:57 PM   #10 (permalink)
so they can just replace the flex pipe and weld it in place of the old one? Not sure about the lower mounts, however I know the dogbone one is in bad condition.
Mine:
Wifes:
Old 02-23-2010, 08:06 PM   #11 (permalink)
抵抗は無駄です
fenixus's Avatar
yes essentially that's what they do
if your dog bone is cracked then i would replace bottom mounts as well. that's what i did after first replacing the dog bone (with minimal improvement a idle). bottom ones appeared to be worn/loose as well which also caused the flex pipe to become torn open.
i also replaced the transmission mount, but for some reason i suspect they screwed it up as last vibrations i got still at idle come from that area again over time.
