self etching primer vs sandable primer vs normal primer for painting alloy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2010, 09:41 PM   #1 (permalink)
View sssgood's Photo Gallery
Question self etching primer vs sandable primer vs normal primer for painting alloy
ok guys I wanted to paint the stock alloy on my 95 camry black, might not be that pretty but meh. anyway so doing a bit of research I learned that first I clean the rim, then put primer on it, then 1-2 layers of paint, then 2 layers of clear coat (to make it shiny ). but when I went to get the primer there were 3 types, one was sandable, then self etching, then the normal cheap one. so my question is which one should I get? and I want the paint to stay like at least 1.5 years, so is there something else i should put on (like I heard paint doesnt stick to alloy very well),
thanks in advance
sssgood is offline   Reply With Quote
Old 02-22-2010, 10:44 PM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Theres allot to it these days. . .
Bare metal surfaces that cant be sanded easily is where self etching primer is best. What condition are they in?
You still need to sand chips and nicks out, it won't fill the holes so those need filled too. You also need to get the wheel spotless clean. Depending on its condition you may consider bead blasting to get the surface uniform. Alloy's and salt can take off and corrode depending on where you live and condition they're in. Bead blasting with clean beads will solve this. Don't sand blast with salty sand. Self defeating. . .
Are you looking at base coat clear coats? Cause now you need a good gun and clean air to spray them with. This can all add up. . .
Keep reading, lots to learn. Drop a note if ya need some input.
73sport is offline   Reply With Quote
Old 02-23-2010, 12:41 AM   #3 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
hope this helps!
first mod of 2009!!- wheels! pics inside..
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 02-23-2010, 01:03 AM   #4 (permalink)
Originally Posted by ONE_to_HATE View Post
does that go for alloy as well?
Old 02-23-2010, 01:05 AM   #5 (permalink)
they are in pretty good condition, just cleaned them up real well (there was some brake dust). and what's bead blasting?
