95 l4 timing belt qeustion NEED HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2010, 03:02 PM   #1 (permalink)
stlwil's Avatar
View stlwil's Photo Gallery
3rd Generation 95 l4 timing belt qeustion NEED HELP
just changed my t belt. it was very loose ,i went about 240,ooo miles on it.all the marks were on the money .runs fine no backfires or anything like that ,BUT the idle has droped about 150-200 rpms now ,STILL PRETTY SMOOTH tho. and it struggles upon acceleration just a bit,but not bad enough to backfire or anything,during the 240k miles on the belt i had my ignition timing adjusted,QEUSTION IS DO JUST NEED TO HAVE MY IGNITION TIMING RESET????? BY THE WAY THE PLUGS ARE NER NGK IR 9.NGK WIRES NEW,CAP ROTOR, PLEASE HELP THROTTLY BODY IS CLEAN
stlwil is offline   Reply With Quote
Old 02-23-2010, 03:22 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i would say recheck the timing
^ and leaving it that way!
Old 02-23-2010, 03:38 PM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
change timing belt should not have any affect on engine performance, unless the old belt was broken or very loose.
if it struggles upon acceleration, i suspect the timing is 1 tooth off,
it had happen to me, start up and idle fine, but no power upon acceleration.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 02-23-2010, 03:46 PM   #4 (permalink)
stlwil's Avatar
yes it was VERY VERY loose it had 240000miles on it. it still gets up and goes really good,its renning like it has a slight mis ,reallyslight mis. ps i had the car since it had 14 miles on it
Old 02-23-2010, 04:06 PM   #5 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah your off a tooth for timing. If its only a tooth off usually is runs just not so great just like your describing.
carsrus is offline   Reply With Quote
Old 02-23-2010, 04:32 PM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
If I understand correctly, you had the ignition timing "tweeked" while the old belt was on there to compensate for the stretched belt, but haven't reset the timing since the new belt was installed. In that case, yes, you should reset the timing before messing with anything else.
The Following User Says Thank You to hill8570 For This Useful Post:
stlwil (02-23-2010)
Old 02-23-2010, 07:08 PM   #7 (permalink)
stlwil's Avatar
update checked ignition timing with light and it is a little more than 10 degrees off, it is a little to the right of the 0 mark,standing on the passenger side looking in
Old 02-23-2010, 07:44 PM   #8 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
Wow I never heard of car going 240000 miles with the original Timing Belt. Amazing. But I agree with others that your timing is 1 tooth off. Fix that and your good for another 240,00 miles
johnfrisco is offline   Reply With Quote
Old 02-23-2010, 09:30 PM   #9 (permalink)
hill8570's Avatar
That's pretty retarded (in a timing sense).
Take a paperclip and jumper the TE1 and E1 pins on DLC1 (DLC1 is the test connector up near the passenger side firewall...the underside of the cover shows the locations of the pins). With the tranny in neutral (and the parking brake well set), check the timing -- it should be 10 degrees BTDC (the 10 to the left of the zero when facing the engine from the passenger side). If not, loosen the two distributor bolts (one underneath the dizzy, one to the left of the dizzy), and rotate it a smidge until timing is 10 degrees BTDC, then tighten down the dizzy bolts. Pop loose the jumper on the DLC, and recheck timing -- it should be in the 5-10 degrees BTDC range (it will wander a bit).
If that doesn't fix your problem, then, as lots of others have mentioned, your belt is a tooth off, although I think your timing would be off more than that if it were a tooth off (although the number of degrees of timing per tooth escapes me at the moment...)
stlwil (02-23-2010)
Old 02-23-2010, 09:50 PM   #10 (permalink)
stlwil's Avatar
will do in the morning
