Installing DEI 5701
So I'm installing a 5701 and I have everything down except for the remote start part.
It has 9 input wires for the remote start heavy gauge part:
(+) IGNITION 1 INPUT/OUTPUT
(10A) FUSED IGNITION 2 / FLEX RELAY INPUT 87
ACCESSORY OUTPUT
(+) STARTER OUTPUT (CAR SIDE OF STARTER KILL SWITCH)
(+) STARTER INPUT (KEY SIDE OF KILL SWITCH)
(+) FUSED (30A) IGNITION 1 INPUT
(+) IGNITION 2 / FLEX RELAY OUTPUT
FLEX RELAY INPUT 87A KEY SIDE OR FLEX RELAY
FUSED (30A) ACCESSORY/STARTER INPUT
So I figured I'd cut the starter wire, and attach it to the Starter input and outputs, car side and key side appropriately. Connect Ignition 1 to the top (+) IGNITION 1(input/output). Ignition 2 to (+) 30A FUSED IGNITION 2/FLEX RELAY INPUT 87, and finally the accessory out spliced into the accessory wire.
So my question is, where should I connect the ignition wires to on the Alarm?
There is the ignition 1 input/output but then there is another dedicated Ignition 1 input, should I connect the car's ignition 1 wire to both or just the input/output one?
Also, which one should I connect Ignition 2 to? - '(30A) Fused ignition 2/flex relay input 87'?
Finally, do I need to connect a wire to the "accessory input" or can I just splice the accessory output into my accessory wire?
