I blew my 1mz-fe and now have a 2mz-fe (2.5L) from japan in my es300.Is there anything to worry about? i use the Tb from my 1mz-fe.. is this engine any good? any performance parts available? is a 5speed swap possible? i used my 1mz-fe auto tranny with a 2mz-fe bell housing.
the only adverse effects i can see is a possible decrease in power (not sure what the performance # of the 2mz are), i would have said electronics would be a bitch but if youve already done the swap and all is well then your ok.
there are performance parts avalible for the 1mz and unles the heads/intake manifold are greatly different i would assume the headers and TRD charger would fit...if you wanted to go that route. other then that there really arent any other engine parts avalible for the 1m or 2m.
you can do a 5 speed swap just like the 1mz, it shoudl bolt right up.
form what i read the specs are almost the same but it is running a higher cr i believe 10.7? seems to have a lower tq number tho.
i guess if the only thing you had to change was the tb to make it all work you should be find and clear to go on the swap you just need to try and find the parts.
but tho i would like to see if it ran a different cam profile
also the 2vz was never a usdm engine so there isn't much information that we know about it.
^ and leaving it that way!
thanks....It's actual has 200hp; little more than my 94-96 1mz-fe. I already switched the intake manifold to my 1mz intake manifold..I do have a check engine light but not sure why..any ideas?
The 5speed es has the 3vz which i don't want and are extremely rare. i already have the 2mz in my es which bolts up to the e153 5speed...The 2mz feels faster than my 1mz but that's probably due to the engines low mileage.I also see an improvement in my gas mileage.
Ye the numbers are around the same and i already did the tb swap. thanks for the help
pull the codes from the ecu, just take it to autozone they will do it for free
well you need interior parts so your going to have to find that 3vz es
try hitting up 2wickedtoys and asg14 (adam) they are near you (well for like this week adam is) i think gino might have a few things laying around you might be able to buy from him ....... heck i might be able to sell you a pretty good flywheel for this
ye i'm going to bring it there and see what it says. i spoke to gino b4 and how much would u sell the flywheel for?
1999 Solara v6 auto 13.0 @113mph s/c'd 9.5psi and nitrous
2000 Camry v6 5 speed 13.5 at 107.3mph s/c'd at 7psi
1997 Camry i4 auto to v6 auto swap! Built 3.3 3mz/1mz hybrid
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
I'm sure i'll hear about this sooner or later from someone. Good luck, man.
