On my current daily driver (1995 Camry, 105,000 -- mostly in-town -- miles)
"Had to" replacements:
Tires
Battery
Front and rear struts
Rear end links
Rear strut plates
Radiator
transmission cooler hoses (weren't leaking, but the ends were cracked)
charcoal canister TVV (leaky)
distributor o-ring (maybe not "had to", but it was leaking down the engine)
distributor dust seal (self-destructed while replacing the o-ring)
valve cover gasket and tube seals (again, leaking, but could have lived with it)
radiator overflow tank (self-destructed)
starter solenoid contacts and plunger
radio / cd player
antenna (multiple mast replacements...finally ripped out the POS power antenna and put in a regular one)
couple of lights in the combo meter
air conditioning expansion valve
air conditioning receiver / dryer
cruise control actuator
both half-axles
engine mounts (replaced all four...probably overkill, but what the heck)
"Maintenance" replacements
oil / oil filters
coolant
transmission fluid
dropped and cleaned out the transmission pan
power steering fluid
brake fluid
PCV valve, grommet, and hose
timing belt
water pump
thermostat
radiator cap
all the coolant hoses
gas cap
spark plugs
spark plug wires
distributor cap
distributor rotor
fuel filter
air filter
radiator overflow tank hose
both oxygen sensors
"on the to-do list"
replace the passenger side oil seals (currently leaking enough to drip on the garage floor...grrrrr)
replace the brake flex lines (no rush...I just don't trust 15 year old rubber)
replace or rebuild driver's side half axle (again
). No noise, but the boot's ripped
drop and clean out the oil pan (had to clean a lot of sludge out of the top end, so I assume the pan is pretty nasty)
I'm also trying to track down a faint raw gas smell immediately after the car is shut off -- still haven't found the cause.
