O2 Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2010, 08:17 PM   #1 (permalink)
View arthur.aaragon's Photo Gallery
O2 Sensor
I have 92 camry with 150,000 mileage, the engine check light comes on once in a while. I know that there are two sensors,one before and one after the catalytic. Does anyone replaced the sensor recently? I am planning to replace both of them but not sure what type of sensors to buy. Single or 4 wire? Where is the cheapest shop to buy these sensors?
TG4567
arthur.aaragon is offline   Reply With Quote
Old 02-25-2010, 08:54 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
http://www.off-road.com/toyota/tech/codes/
find out what the codes are might be something else
rockauto for all my parts, also search for a coupon or pm me there normally like 50 5% off coupons floating around
^ and leaving it that way!
Old 02-25-2010, 09:11 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Definitely read out those codes before dropping $$$ on shotgunning parts. Then we can talk about what and where to buy
Old 02-28-2010, 09:14 AM   #4 (permalink)
O2 Sensor
That paper clip technique worked! I got code of two 5 and i checked that there is no 55 so i believe its 5. It says 5 is for oxygen sensor, which of the two sensors might this be? Thanks for your help!
TG4567
Old 02-28-2010, 09:21 AM   #5 (permalink)
O2 Sensor
I read in the previous post that there is a code 55 and it is the knock sensor. Is the knock sensor cheaper to replace than oxygen sensor?Where is this located?
TG4567
Old 02-28-2010, 11:56 AM   #6 (permalink)
hill8570's Avatar
On the 3VZ, DTC 55 is the code for "No signal from Bank 1 knock sensor". Usually a bad knock sensor, although could be fried wiring or a loose sensor. Real outside chance of bad ECM.
Offhand I can't remember if Bank 1 is near the firewall (bad, as in "real pain in the ass to get to") or near the radiator side. I'm heading out the door -- hopefully someone else can chime in on this one, otherwise I'll look it up tonight.
Old 02-28-2010, 03:31 PM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
^Yeah, bank 1 is near the firewall.
BMR is online now   Reply With Quote
Old 02-28-2010, 08:17 PM   #8 (permalink)
Knock Sensor
I'm not good locating the bank 1. Do you have picture or diagram showing the knock sensor for 92 camry v6 3.0?Many thanks!
TG4567
Old 03-01-2010, 09:52 AM   #9 (permalink)
hill8570's Avatar
Go to www.camrystuff.com , Generation 3, go down to the Lexus-specific stuff at the middle of the page (yeah, I know you don't have a Lexus...bear with me), and download the FSM for the '93 ES300. The "Engine" section in there has a good write-up on the 3VZ with locations of all the sensors -- for all practical purposes you've got the same engine.
Old 07-16-2010, 11:23 AM   #10 (permalink)
View 1fastRR's Photo Gallery
I'm trying to change the rear o2 sensor on my 2001 I4 and the clip seems to be inside the center console. There is a grommet and I can't unclip it. Can anyone give me insight as to an easy way to change this? Do I really have to take out the center consoel?
1fastRR is offline   Reply With Quote
Old 07-16-2010, 12:44 PM   #11 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
You have to remove the driver's side seat.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
The Following User Says Thank You to Jason.MZW20 For This Useful Post:
1fastRR (07-16-2010)
Old 07-16-2010, 03:11 PM   #12 (permalink)
Come on! lol. Are you serious?
Old 07-16-2010, 04:34 PM   #13 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
99 4cyl Camry O2 Sensor wire path?
Have fun it's easy.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
The Following User Says Thank You to csaxon For This Useful Post:
Old 07-16-2010, 06:51 PM   #14 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Easy as it is, no one wants to see this written. FWIW, i'll take it over a rusted exhaust bolt any day.
73sport is offline   Reply With Quote
