Originally Posted by SmitsYoda
So guys the car has had the check engine light one since we had it. I'm trying to solve my mom money but she wants the CEL to go away she said her gas mileage isn't good either. if i changed the plugs and wires do you think that would fix it? I'm trying to help her out as much as possible.
no, it won't fix P0420. it may help healing some of MPG issues you having.
to get rid off P0420 code, you would need to track it down and there are several things that need to be checked (including upstream exhaust leak). most likely car has a shot upstream catalytic converter though, since it was driven with bad upstream o2 sensor since you bought it. this may have plugged the cat with all the crap resulting from untuned engine operation (false o2 readings received by ECU).
however if you replace plugs & wires and all filters (fuel & air) and then you still have MPG issues, then there will be only 2 more things responsible for it: bad catalytic converter (likely in your case) or clogged fuel injectors (unlikely).
of course you can go ahead and replace the front cat, but this is a shot in the dark, there is no guarantee this is the root cause. for some people issue was coming back even after replacing it.
more here:
http://www.camrystuff.com/manuals/Gen4/Diagnostics.pdf
for 5s-fe engine (4 cylinder):
page DI-116 for Federal emissions type (regular upstream o2 sensor)
page DI-119 for California emissions type (wideband A/F upstream sensor)
