Is my transmission dead? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2010, 08:33 PM   #1 (permalink)
View LUVLEXUS101's Photo Gallery
So after rocking my car back and forth in the snow on Thursday, the past few days the transmission has been acting up. Sluggish shifts. Rumbling while accelerating. Finally today it died on me, it first would only engage in 2, and then finally it pretty much stopped engaging completely. I barely got it home doing about 15 mph the entire way. If I pressed the gas too hard, it'd slip out and I'd be going no where. Sadly, I had just installed my 2 way viper remote start yesterday. :/
Question: Does this mean my transmission is dead?
On a side note, which automatic transmissions will fit? Can the i4's fit, or the 1mz camry trannies fit, maybe the es300?
LUVLEXUS101 is offline   Reply With Quote
Old 03-01-2010, 04:48 AM   #2 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
It probably needs a rebuilt, as it is toast! How many miles did it serve you?
ricamryman is offline   Reply With Quote
Old 03-01-2010, 09:39 PM   #3 (permalink)
147k
What do you guys think about this one?
http://cgi.ebay.com/ebaymotors/92-93...Q5fAccessories
I emailed them, they said it has < 60k miles
Old 03-01-2010, 09:50 PM   #4 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
You can try repeatedly changing the fluid after installing a brand new filter.
The transmission in my Mother's Avalon was slipping like crazy and not shifting properly. We changed the filter and changed the fluid about a dozen times and it came back to life. That was almost 100,000 miles ago. Been perfect ever since. They're tougher than you might think.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
The Following User Says Thank You to gideon1331 For This Useful Post:
AlmightyCamry777 (03-03-2010)
Old 03-01-2010, 11:14 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
+1. The transmission probably dump a lot of clutch and steel material into the fluid. The Aisin transmissions didn't have any decent filtration, so these debris can cause problems with the valves.
Old 03-01-2010, 11:50 PM   #6 (permalink)
I'm gonna give it a try wednesday, filter and gasket from dealer and a couple gallons of fluid.
Old 03-01-2010, 11:57 PM   #7 (permalink)
Or you can pick up a Fram ATF kit from your local parts store ~$15-20 strainer and pan gasket. 3-4 gallons of Walmart Dexron-III type fluid for 3 drains/refills if you don't do the cooler line flush. < $10/gal works fine too.
Check the amount of sludge at the bottom of the pan and on magnets. Note condition of fluid drained. Cleanliness and fluid level accuracy are important.
So check and note the ATF level on the dipstick, measure and add same amount back in is the easiest.
Old 03-02-2010, 10:26 AM   #8 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Call me the pesimist, but it don't sound like a bounce back situation.
Did you check the fluid level with engine on and trans in park? Is it burned to a crisp?
Weren't you posting before about tranny troubles?
Give it a SMELL! If its fried you'll know it. Does rewind work or just 2nd gear?
73sport is offline   Reply With Quote
Old 03-02-2010, 10:57 PM   #9 (permalink)
It reversed today, solid, and it moved forward slowly hitting around 5k, but when the car is running it makes a really strange sound like a pump or something, the fluid looks pretty brown but I can still see some red in it
Old 03-02-2010, 10:58 PM   #10 (permalink)
Never posted about tranny trouble before, right before it died I was pushing 90 plus and after I got to my destination and parked for a while, later on it was almost dead, did about 20-30 home for 6 miles
Old 03-03-2010, 08:25 AM   #11 (permalink)
Fluid looked like chocolate, only a quart or 2 was in there, I refilled with clean fluid and it reversed for a bit, and struggled forward then stopped engaging completely. Gonna go grab a tranny filter and some more fluid after class.
Old 03-03-2010, 11:14 AM   #12 (permalink)
View AlmightyCamry777's Photo Gallery
If there was ever a time for a flush this is it! Nothing to lose so flush it, you cna disconnect hoses to flush or just drain, refill and drive for 20 miles (if it will work, or just idle the engine 10 minutes), repeat twice. THEN drop the pan and change/clean the filter and repeat the first draining and refilling twice more or until nothing but new fluid comes out. If a fluid change will bring it back from the near-dead this might do the trick.
AlmightyCamry777 is offline   Reply With Quote
