95 l4 trans mission mount replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2010, 05:43 PM   #1 (permalink)
stlwil's Avatar
View stlwil's Photo Gallery
3rd Generation 95 l4 trans mission mount replacement
never done this one any one have any info?
auto trans
stlwil is offline   Reply With Quote
Old 03-01-2010, 08:38 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Well, it's seldom necessary (of the four "motor mounts", the one at the transaxle takes the least amount of abuse). If it needs replacing, easiest way in in through the driver's wheel well -- loosen wheel nuts; jack up front of car and set jackstands (preferable short ones) on both sides; remove wheel; loosen nuts on the mount; jack up engine a bit using a floor jack and a 2x4 against the oil pan (may have to remove the top bolt on the front engine mount to get enough movement); switch out mount; lower engine; bolt everything back together.
