differences between gen4 camry federal vs california emissions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2010, 11:36 PM   #1 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
USA differences between gen4 camry federal vs california emissions
Can anyone list all different parts used on gen4 camry between federal and california emission versions ?
so far i read about:
-different ECU programming (my ecu identifies itself as "california II ARB", "OBDII California", etc.)
-cali has the A/F o2 sensor (wide band) while federal has regular o2 sensor (narrow voltage range) same as in rear; also location of front sensor in exhaust manifold is different
-cali has two catalytic converters (in front and rear) while federal has only one in rear
-throttle body and IAC modules are different, cali version has Air Assist ports on IAC and cylinder head, federal doesn't
are there any other differences ?
thanks.
