1mzfe turbo injector question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2010, 01:42 PM   #1 (permalink)
Odasi
jhlaird's Avatar
View jhlaird's Photo Gallery
I am wondering what injectors I can use for a turbo set up on my 1mzfe? I am going to use a STM6 piggy back which can control bigger injectors plus a FPR. Right now I am looking a using 460cc 88-91 rx7 non turbo injectors Pt. #195500-2010. Will these work/fit? Some people said to use non turbo Supra injectors, these are smaller but will they work as well?
jhlaird is offline   Reply With Quote
Old 03-05-2010, 02:01 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
yes
sooooooooooooooo that smt6 can control the injectors or adjust the readings so the ecu will fuel more or less?
^ and leaving it that way!
Old 03-05-2010, 02:16 PM   #3 (permalink)
Odasi
jhlaird's Avatar
Yes the rx7 injectors will work/i can just put them in and go? Yes, the SMT6 can do that, at least that what the guy at Ida Automotive told me, which is where I bought it from.
Old 03-05-2010, 02:28 PM   #4 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
it all depends on what your power goal is and whether you are building your motor or not.
let's say if u want to get your 180WHP 1MZ to 230WHP...then u don't need bigger injectors, but then what's the point of gaining 50whp when ur going turbo right?
from 250~350WHP, non turbo supra injectors will be alright. IIRC they are 315 cc/min.
470cc/min is a really high jump and it will probably be good for 500whp, but then your stock long block will explode with that kind of power.
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 03-05-2010, 03:37 PM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
that goes for SCed but IIRC he needs bigger injectors because hes turbo. dont quote me, but i think ive seen that several places.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-05-2010, 06:12 PM   #6 (permalink)
Odasi
jhlaird's Avatar
I'm leaning towards the rx7 injectors because I can lean them out if I need to. I just wanna know that they will fit and work.
Old 03-05-2010, 09:25 PM   #7 (permalink)
96 3MZ M/T
chronoti's Avatar
will fit and work
smt6 is out dated big time i bought mine 5 years ago , the smt 8 is out and better because it does dual o2 sensor augmentation over the single of the smt6
also the smt6 will not control the injectors like a stand alone (i.e. megasquirt) it will just adjust the maf reading so it will think it is pulling cooler (richer) or hot (lean) air
now if your running an ct26 stay stock, slightly larger go supra, if your going to boost on the rx7 your going to need standalone or else the ecu will freak when going -60% to 0% correction, also the stock ecu will not adjust too well over 20%
The Following User Says Thank You to chronoti For This Useful Post:
jhlaird (03-06-2010)
Old 03-05-2010, 09:59 PM   #8 (permalink)
engineer in training
Gameroom cash: $145055
Yeah tuning will be tricky unless you are experienced, go with 20% over stock and get a rising rate regulator for an easier setup.
Luckynumber5 is online now   Reply With Quote
Old 03-06-2010, 08:23 AM   #9 (permalink)
Odasi
jhlaird's Avatar
I was orginally going to get a SMT8 but a couple of the dealers told me that they were having probems. One dealer told me that they don't even sell the SMT8 because it had too many kinks in it still.
What year non turbo supra are those 315s from? Part number? I think I will get these.
Old 03-06-2010, 09:03 AM   #10 (permalink)
Odasi
jhlaird's Avatar
Will someone please check out this link and tell me if these will work?
http://cgi.ebay.com/ebaymotors/315cc...Q5fAccessories
This is what I found on another post. The part number is close but not the same.
OEM Camry 3.0L V6 (1MZ-FE) fuel injector Denso part # 23250-20010
- 14.7 ohm / 244cc @ 43.5 PSI (3 bar)
OEM Supra N/A 3.0L V6 (2JZ-GE) fuel injector Denso part # 23250-46030
- 13.4 ohm / 312cc @ 43.5 PSI (3 bar)
OEM 89-91 RX-7 (Engine ?) fuel injectors Denso part # 195500-2010
- 13.8 ohm / 460cc @ 43.5 PSI (3 bar)
OEM 89-91 RX-7 (Engine?) fuel injectors Denso part # 195500-2020
- 13.7 ohm / 545cc @ 43.5 PSI (3 bar)
Old 03-07-2010, 04:33 PM   #11 (permalink)
Odasi
jhlaird's Avatar
Will someone please check out these injectors and tell me if they are right? How bad will the ecu freak out if I use the 460s? Which one should i use?
460cc rx7 injectors
http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
315cc non turbo supra
Old 03-07-2010, 06:35 PM   #12 (permalink)
Let The Awakening Begin
Red_T_SwiftCam's Avatar
iTrader Score: 6 reviews
View Red_T_SwiftCam's Photo Gallery
Im not sure what your power goals are,but the 1mzfe uses top feed fuel rail which makes it easier to fit larger fuel injectors so your fine.Making any Major changes to your engine like this as chronoti stated will make your ecu unhappy. Piggy back standalone you choose.
Calculations:
Starting with the Flow figure of 315cc
315cc/5=63hp. 63hp= Maximum fuel flow with the 315cc injector.
63(hp)X6(Number of injectors you will be using)=378hp(100% duty cycle)
378(hp)X0.80(80% duty cycle)= 302.4hp at 80% duty cycle Which is were you want to be.
Thats what you would be getting with the 315cc injectors.
Red_T_SwiftCam is offline   Reply With Quote
