unintended acceleration in 2 mode O_O
hey guys,
the other day people recommended I get sea foam to decarbonize my engine, so after the wait I took it for a drive in 2 mode (so the rev is always high and stuff). ok so after doing a left turn and accelerating a tiny hard my rev went from 3.5k all the way to 7000!!!!! it was freaking scary! I pushed the break, wouldn't work, i actually thought the break turned into the accelerator for amoment but ya then i put it in neutral, the engine was at max rev!! put it into d, it pulled hard again!, so then I put it in neutral and turned of the engine, and braked. that 10 second was like the scariest moment ever!! after putting on the hazard light (blocking traffic >_>) i turned on the engine in neutral...the engine revved all the way to 7000 again right off the start, samething happened in parking mode, opened the hood, the throttle wire was loose! so I went back in to the car, turned the engine at neutral, when the engine started revving high again i like pushed the accelerator acouple of times..and then it came back to normal!!!!
so what HAPPENED????? did the wire like get stuck or something?
mabey I should go see a mechanic and get the throttle wire checked?
by the way its a 1995 camry V6 LE
thanks
