99 Camry with a P0440 and another... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2010, 09:11 AM   #1 (permalink)
Rabid Teddy
Ace2424's Avatar
View Ace2424's Photo Gallery
4th Generation 99 Camry with a P0440 and another...
I have a beautiful 99 that has had the same check engine light for all of the colder season. the thing is, it only comes on when it's below 40 degrees F. I get the P0440 and another that says Evaporative Emissions Purge Valve Malfunction/Insufficient Flow.
Does this mean my valve is bad and needs to be replaced? I've had some trouble locating it. Where exactly is it and how do I replace it? I'm going to tap it with the end of a screwdriver to see if I can unjam the solenoid and have added some K100 to the fuel tank to see if I can get the moisture out. Any suggestions or help would be great.
The car has 209,000 miles with a beautiful rust-free body and I'm trying to keep it as long as possible. Thanks in advance!
Super White 1994 Celica GT 5SFE 5-Speed - 150,000 Miles - Still Driving
Vintage Red Pearl 1999 Camry 5SFE - 216k Miles - Totaled R.I.P.
Ace2424 is offline   Reply With Quote
Old 03-06-2010, 08:29 PM   #2 (permalink)
View sherbear123612's Photo Gallery
Technical Description
Evaporative Emission System Malfunction
What does that mean?
This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge opens allowing intake vacuum to siphon the fuel vapors into the.
Symptoms
You likely won't notice any drivability problems.
Causes
A code P0440 could mean one or more of the following has happened:
  • The gas cap is not installed or working properly
  • The purge solenoid has failed
  • The canister is plugged and not working properly
Possible Solutions
With a P0440 OBD-II trouble, diagnosis can be tricky at times. Here are some things to try:[LIST][*]Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.[*]Inspect the EVAP system for cuts/holes in tubes/hoses[*]Inspect for damaged or disconnected hoses around the Evap purge solenoid[*]Check and/or replace the sensor[*]Check and/or replace the purge valve[*]Have a professional use a smoke machine to detect leaks
Other EVAP DTCs: P0440- P0441- P0442- P0443- P0446- P0453- P0455- P0456
sherbear123612 is offline   Reply With Quote
Old 03-06-2010, 08:44 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There is a vacuum switching valve(VSV) on the air filter housing. You'll see a rubber hose leading to the throttle body, and the other hose connects to one end of the evaporative system pipe.
That VSV probably needs cleaning (careful not to break the metal fingers or you'll need to buy a new one ~$50). This is not the correct picture, but looks like this:
http://www.rockauto.com/catalog/moreinfo.php?pk=817604
You can temporarily pull the hose on the canister side and listen for repeated, loud sucking sounds the VSV makes as it opens to the vacuum on the throttle body side.
Ask a mechanically inclined friend or shop for help if needed.
Old 03-07-2010, 10:31 PM   #4 (permalink)
Rabid Teddy
Ace2424's Avatar
I have already replaced that valve. The issue is not there. I also know what the codes mean I just need to know where to find the purge valve and how to replace it.
Old 03-08-2010, 02:33 PM   #5 (permalink)
Check Out That Camry!!!!
CAMRYTUNER20's Avatar
View CAMRYTUNER20's Photo Gallery
4th Generation
Here is a picture of two of the three vsv's on your car. The other vsv is the vapor pressure vsv and it is located on the charcoal canister. Hope this helps!!
KEEP THE PIMP HAND STRONG!
CAMRYTUNER20 is offline   Reply With Quote
Old 03-09-2010, 12:20 AM   #6 (permalink)
Rabid Teddy
Ace2424's Avatar
I believe it's the one on the charcoal canister. How much will one of those run me?
Old 03-09-2010, 02:18 PM   #7 (permalink)
4th Generation
Well i work at a dealership and it runs about 80 bucks here, but im sure you can find it cheaper some were. But that doesnt guarantee that going cheap is 1. going to fix it and 2. last. But good luck!!! whatever you do.
